7606 MPLS QoS question
Oerlikon_NZ
I have built an MPLS core(2 x 7201, 2 x 7606), and I am trying to implement QoS matching on MPLS EXP.  I am using LLQ-priority for voice class-based guaranteed bandwidth for other traffic.  This works well on the 7201's, but I have discovered the 7606 does not support LLQ 'priority' or 'bandwidth' on WS-X6724-SFP interfaces.  This has really thrown a spanner in the works.
I've read the following docs for QoS on the 7600 - http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/ngmaneplat.html#wp1065474 , however it appears queuing is based on DSCP or COS values?  Will this work since the L3 egress (WAN) interface I need to apply QoS is MPLS enabled?
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
The 7600, I believe, uses actual internal CoS markings for directing traffic to egress queues, but also believe you can map various DSCP markings into the internal CoS markings.  I.e., you can indirectly prioritize based on DSCP.  (I think something similar is possible if using MPLS EXP markings.)
Correct, the 6724 card doesn't support LLQ or bandwidth, but you can define on of the queues to be a priority queue, to take the role of LLQ, and other queues can be assigned weight (effectively giving them ratios like the CBWFQ bandwidth statement).  Compared to a 7200, you only have 4 queues to work with, and the LLQ like PQ doesn't offer an implicit policer.
