07-14-2014 03:11 PM - edited 03-04-2019 11:20 PM
Dear all
I have problem with RSP720 backup module installed on Slot 5, all leds are in Ambar status. I am planning to plug it out and plug it in, trying to deterine if there is hardware issue. Compact flash is no inserted, I just inserted with IOS running on Slot6. I would like to know how to switch between module 6 and module 5. If those RSP720 are installed, one should be in ACTIVE status and the second one is STANDBY?
#sh module all
Mod Ports Card Type Model Serial No.
1 0 4-subslot SPA Interface Processor-400 7600-SIP-400 JAE13208UDD
4 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAL1122QCWK
5 0 Supervisor-Other Unknown Unknown
6 2 Route Switch Processor 720 (Active) RSP720-3CXL-GE JAE13030OMS
9 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1122QAJY
Mod MAC addresses Hw Fw Sw Status
1 0025.845a.5c40 to 0025.845a.5cbf 2.7 12.2(33)SRC4 12.2(33)SRC4 Ok
4 001b.d45d.e2a0 to 001b.d45d.e2b7 2.6 12.2(14r)S5 12.2(33)SRC4 Ok
5 0000.0000.0000 to 0000.0000.0000 0.0 Unknown Unknown Unknown
6 001c.584c.b590 to 001c.584c.b593 5.7 12.2(33r)SRD 12.2(33)SRC4 Ok
9 001b.d50e.4b10 to 001b.d50e.4b3f 2.5 12.2(14r)S5 12.2(33)SRC4 Ok
Mod Sub-Module Model Serial Hw Status
1/0 2xGE SPA SPA-2X1GE JAE1119G244 2.2 Ok
1/1 2xGE SPA SPA-2X1GE JAE1119G23T 2.2 Ok
4 Centralized Forwarding Card WS-F6700-CFC SAL1121PPGN 3.1 Ok
6 Policy Feature Card 3 7600-PFC3CXL JAE130316K6 1.0 Ok
6 C7600 MSFC4 Daughterboard 7600-MSFC4 JAE13030T61 1.1 Ok
9 Centralized Forwarding Card WS-F6700-CFC SAL1121PPHH 3.1 Ok
Mod Online Diag Status
1 Pass
1/0 Pass
1/1 Pass
4 Pass
5 Not Applicable
6 Pass
9 Pass
#sh module 6
6 Pass
7609-HE-CCS#sh module 5
5 Not Applicable
Solved! Go to Solution.
07-15-2014 01:07 PM
First of all connect to the console port of the RSP in slot 5 and hit Enter a couple of times in the terminal program that you're using. If you get a "rommon>" prompt just send it the "boot" command - assuming the hardware is fine and nothing has happened to the RSP's IOS image, it should boot and become the stand-by supervisor for the chassis. If that happens successfully you can then take a look at possible causes (like incorrect config register) of the RSP getting stuck in the ROM monitor...
07-15-2014 02:36 PM
"redundancy force-switchover" should turn the currently Hot supervisor Active
07-15-2014 07:18 AM
Maybe the RSP is stuck in ROMMON - attach a console to it, and if that's the case just "boot" it and you can debug the situation further after it's up (maybe somehow it lost the correct value of the config register)...
07-15-2014 07:31 AM
Dear IVAIDEANU, how can I boot RSP? Cisco 7609 is running and RSP Slot 6 is active, if I work with Slot 5 may cause issue on all system? Let me know which command can I apply for ROMMON status. Once is on active status, are those RSP active? or on in Active and the other one in STANBY?
07-15-2014 01:07 PM
07-15-2014 02:19 PM
Hello IVAIDEANU, RSP is working now:
7609-HE-CCS#show module all
5 2 Route Switch Processor 720 (Hot) RSP720-3CXL-GE SAL1544UB9M
One more question. how can I turn active RSP Slot 6, in order to be sure that is OK, and Slot 5 in Hot status?
07-15-2014 02:36 PM
07-15-2014 03:07 PM
Dear ivaideanu, thanks a lot for your help, really usefull your support. Apreciated
Best Regards
