800 Series doesn't get beyond PADO on Annex J
Dan Jay
Dear all,
I'm configuring an 886 VA (J) to run on an Annex J line ( Deutsche Telekom All-IP / NexGen ).
The router is getting its CD LED on, and according to the pppoe events/packet debugs it is constantly sending out PADI requests and there is no PADO coming back. Because I don't succeed in that, I don't get to bring up the pppoE  session etc. I called the ISP to have them check things  - no results, all fine.
Debugging my dialer results in the traffic getting marked as interesting but fails to be sent out because there is no free dialer (because no dialer binding has occurred and no public IP was assigned.)
What should I post in here for you to look at ?
Dan
5 Replies 5
acampbell
Hi Dan,
Can you share your config to help us investigate
Alex
Regards, Alex. Please rate useful posts.
Alex - sorry for being late, the Forums were unavailable for some reason.
Further Investigation reveals that the Provider didn't deliver Annex J but Annex B because of their access Concentrators on the street. The box lives in a pretty rural area and Provider has confirmed being unable to deliver Annex J there, but will check if anything is possible.
I know that a B-capable box can be brought to J by upgrading the modem Firmware, but will a natively J-capable box run on  B ?
Dan
Hi Dan,
That's a hard one to find.
I did find this statement in an older release note
http://www.cisco.com/c/en/us/td/docs/routers/access/800/firmware/release/notes/VDSL2/fwrn35j.html
Note Cisco 880VA Series Multimode VDSL2/ADSL2/2+ Platforms are backward compatible. If necessary, you can download older firmware version at http://www.cisco.com/cisco/software/navigator.html.
Hi Alex,
thanks for investigating. Browsing thru what I have found, it reads "800....optimized for J", at least they don't state it's incompatible. Let's see if the Firmware will run on B; I am waiting for feedback until I revert the config back to ATM mode for B and see if we catch a PADO.
Unfortunately, my SmartNET does not cover the 800 Series @modem firmware , so I will try my best of luck.
I will report to you later, Keep those fingers crossed.
Dan
ThoScheike
Hi Dan,
it's interesting to hear that your Deutsche Telekom All-IP line has been built on a annex b port since they usually try to bring up those products on their MSAN/annex j plattform that's terminated by a BNG. This plattform requires the use of vlan 7 similar to their vdsl lines.
As you can't use the Ethernet0 interface cause it just won't come up on a adsl line, you have to configure a subinterface on the atm0 port and bind your vp/vc and pppoe-client to that.
interface ATM0
 no ip address
 no atm ilmi-keepalive
interface ATM0.7 point-to-point
 pvc 1/32
  bridge-dot1q encap 7
  pppoe-client dial-pool-number 1
According to a quick test I've run, the Cisco 886 VA-J is synchronising on an adsl annex b line just as well as on an annex j line with this firmware:
Modem FW Version: 130205_1433-4.02L.03.B2pvC035j.d23j
Modem PHY Version: B2pvC035j.d23j
Vendor Version: Bpv35j.23j 68
Thorsten
