802.1X authentication server - fail open
mahmoud.yasin
I have 802.1X configured on Cisco (C2960-HBOOT-M) Version 12.2(44)SE5.
I want to configure the switch ports for "fail open", so the original interfaces VLANs will be assigned to users if the radius server goes down.
Here below the current interfaces configuration;
interface FastEthernet0/2
switchport access vlan 10
switchport mode access
authentication order dot1x mab
authentication priority dot1x mab
authentication port-control auto
authentication periodic
authentication timer reauthenticate server
mab
dot1x pae authenticator
dot1x timeout server-timeout 30
dot1x timeout tx-period 10
dot1x max-req 3
dot1x max-reauth-req 3
spanning-tree portfast
0 Replies 0
