819-4G Cellular modem not ready
buglovin1967
Hello.
I have 6 819s that were working in the last few weeks.  All six now show the exact same issue, so I'm sure there has to be a Cisco fix or a Provider fix. We don't get that kind of localized failure otherwise.
All of the routers are returned to me with SIM cards intact, configuration exactly as I left it, but not showing anything for the cellular interface. Here is an example:
#sh cell 0 all
Hardware Information
Modem Firmware Version =
Modem Firmware built =
Hardware Version =
Device Model ID:
Package Identifier ID:
International Mobile Subscriber Identity (IMSI) =
International Mobile Equipment Identity (IMEI) =
Integrated Circuit Card ID (ICCID) =
Mobile Subscriber Integrated Services
Digital Network-Number (MSISDN) =
Current Modem Temperature = 0 deg C
PRI SKU ID = , PRI version =
Profile Information
Profile 1 = INACTIVE* **
Profile 2 = INACTIVE
--More--
*Oct 24 15:28:03.483: %CELLWAN-2-SIM_NOT_READY: Cellular0 Modem is not ready. SIM status may be not .
I  get this on all 6. 2 months ago, I had a similar issue, but just leaving it on my desk running, it eventually reconnected.
Any ideas? We don't keep smartnet on these as the cost is nearly half that of a new 819, so I can't contact TAC.  I have a call into Verizon to see if its APN or tower connection related.  All help is appreciated.
9 Replies 9
johnlloyd_13
Level 9
Level 9
hi,
it's odd all 6 routers' 4G WAN links went down. i suspect a provider issue.
could you post the WHOLE output of show cell 0 all from one of the router.
My thoughts exactly on the strangeness....So another thing that is bugging me. One suggestion I received from a colleague was that maybe the SIM went bad. I replaced a single SIM, activated it, and I'm getting the same issue from that router as well.
Here is the output you asked for...
#sh cell 0 all
Hardware Version =
Device Model ID:
Profile Information
Profile 3 = INACTIVE
Profile 4 = INACTIVE
Profile 5 = INACTIVE
Profile 6 = INACTIVE
* - Default profile
** - LTE attach profile
Data Connection Information
Profile 1, Packet Session Status = INACTIVE
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
--More--
*Oct 25 12:54:50.706: %CELLWAN-2-SIM_NOT_READY: Cellular0 Modem is not ready. SIM status may be noProfile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Network Information
Current System Time = None None 0 0:0:0 0
Current Service Status = Normal
Current Service = Circuit Switched
Current Roaming Status = Home
Network Selection Mode = Automatic
Network =
Mobile Country Code (MCC) = 0
Mobile Network Code (MNC) = 0
Packet switch domain(PS) state = Unknown/Not Applicable
Cell ID = 0
Radio Information
Radio power mode = ON
Channel Number = 0
Current Band = Unknown
Current RSSI = -0 dBm
Current ECIO = -0 dBm
Radio Access Technology(RAT) Preference = No preference specified
Radio Access Technology(RAT) Selected = AUTO
Modem Security Information
Card Holder Verification (CHV1) = Disabled
SIM Status = Unknown
SIM User Operation Required = None
Number of CHV1 Retries remaining = 0
GPS Information
GPS Info
GPS Feature: enabled
GPS Port Selected: Dedicated GPS port
GPS State: GPS disabled
SMS Information
SMS Service is not available
Number of outgoing SMS pending = 0
Error Information
This command is not supported on this platform.
Modem Crashdump Information
Modem crashdump logging: off
hi,
the output shows there's no 4G/LTE service.
does the SIM card/data works on a smartphone? is there data capping or its limit already reached?
are the 6 routers within the same area? check with provider if there's any coverage.
Radio Information
Channel Number = 0
Radio Access Technology(RAT) Selected = AUTO    <<< WILL USUALLY DISPLAY LTE OR UMTS
I was given an answer, but never felt like it was resolved.
According to Cisco TAC, something in the older IOS version I was running allowed the GPS unit to overwrite the location so much it caused a modem failure. Essentially bricking the modems in all of them. I  was told the modem was not a part that could be replaced (which is questionable if you've ever opened an 819), so i had to RMA for new routers.
I was given a specific IOS that was supposedly stable and told to upgrade. I have only had one go bad since then, and the working theory is that it was already bad when i upgraded it.
I can post the IOS version tomorrow when I return to work.
Hope that helps. Its not reassuring. Or at least it didn't reassure me.
Thanks a lot. I actually opened one of my 819s to check in fact if I could replace the modem and you can actually do it.
We have some routers running 15.2(4)M2 and some running 15.3(3M).
The ones that have gone bad are mostly on 15.3, but we have about 30 routers running that code and until now have not failed (a little bit over 3 years online), so the theory that Cisco gave you is a bit sketchy to say the least.
So at this point I am not sure if I should try to find a modem that will work with these or get new routers since they are no longer supported or under contract.
Please let me know about the IOS that was given to you as not being affected.
Thanks.
Field Notice: FN - 64006 - C819HG-xx, C819HG-4G-xx, GRWIC-4G-LTE-x, and CGM-3G-XXXX - Possible Corruption of Cellular Data Modem Firmware - Software Field Workaround Required
http://www.cisco.com/c/en/us/support/docs/field-notices/640/fn64006.html
Thanks Wireman, I would definitely look into this as a possible fix.
Good morning buglovin1967, did you had a chance to look at the stable version for the IOS? I know that the latest version for the 819 is 15.6(3)M2. I wonder if this version should be ok.
Thank you.
Did you ever resolved your issue? I am also getting the same symptoms from a bunch of our 819s. We just purchased a new unit and when I install any of these SIM cards it works on the new router, but I doubt that 6 of our routers went bad. Can it be a problem with the IOS or Firmware? I am just curious if you got it to work.
Here's the output for sh cell 0 all:
dlmnt-xxxxxx-819#sh cell 0 all
Hardware Version =
Mobile Subscriber International Subscriber
IDentity Number (MSISDN) =
Profile Information
Profile password Encryption level: 7
* - Default profile
Data Transmitted = 0 bytes, Received
Inactivity Reason = Unknown
Profile 3, Packet SessNACTIVE
Profile 6, Packet Session StINACTIVE
Network Information
Network Selection Mode = Automaticork =
Registration state(EMM) = Not registered
Cell ID = 0
Primary ScramblingRadio Information
Channel Number = 0
LTE Technology Preference = No preferenceE Technology Selected = AUTO
*May 4 13:34:30.801: %CELLWAN-2-SIM_NOT_READY: Cellular0ready. SIM status may be not current. = Disabled
GPS Information
GPS Info
Son
Error Information
This command is not supported on 4G modems.
p Information
dlmnt-mappsville-819#sh ver
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.3(ENG_SP_153_3M_LTE_20130903)M, EARLY DEPLOYMENT DEVELOPMENT BUILD, synced to V153_3_M
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 03-Sep-13 19:29 by kmenon
ROM: System Bootstrap, Version 15.2(2r)T, RELEASE SOFTWARE (fc1)
ROM: Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.3(ENG_SP_153_3M_LTE_20130903)M, EARLY DEPLOYMENT DEVELOPMENT BUILD, synced to V153_3_M
dlmnt-mappsville-819 uptime is 1 hour, 1 minute
System image file is "flash:c800-universalk9-mz.SSA.eng-sp-153-3M-LTE"
Last reload type: Normal Reload
Last reload reason: power-on
Importers, exporrs, distributors and users are responsible for
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C819HG-4G-V-K9 (revision 6.0) with 883788K/33715K bytes of memory.
Processor board ID FTX171885XX
4 FastEthernet interfaces
1 Gigabit Ethernet interface
1 Serial(sync/async) interface
2 terminal lines
1 Virtual Private Network (VPN) Module
1 Cellular interface
1 cisco Embedded AP (s)
DRAM configuration is 32 bits wide
255K bytes of non-volatile configuration memory.
1000944K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 C819HG-4G-V-K9 FTX171885XX
License Information for 'c800'
License Level: advipservices Type: Permanent
Next reboot license Level: advipservices
dlmnt-xxxxxxxx-819#
Any help will be appreciated.
