Cisco 1941 Router Portforwarding not work.
At one of our client premises they have an Cisco 1941 router. We need to connect from outside (other location branch) with Remote Desktop connection port 3389 to an internal IP address ( a server)and Port 491 is my SAP Port also not working.
DMZ 192.168.1.22
PFA the configuration
ip dhcp excluded-address 192.168.1.1 192.168.1.25
ip dhcp pool DATA
network 192.168.1.0 255.255.255.0
dns-server 202.83.21.12 202.83.20.101
default-router 192.168.1.1
ip domain name yourdomain.com
ip cef
license udi pid CISCO1941/K9 sn FGL211024AM
interface GigabitEthernet0/0
description $wan Internet LINK$
ip address 192.168.0.1 255.255.255.0(Wan IP)
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description $LocAL NETWORK LINK$
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 100 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 192.168.1.22 3389 interface GigabitEthernet0/0 3389
ip nat inside source static tcp 192.168.1.22 491 interface GigabitEthernet0/0 491
ip route 0.0.0.0 0.0.0.0 192.168.0.2
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
control-plane
6 Replies 6
Reza Sharifi
Can try using the IP address instead of the interface:
ip nat inside source static tcp 192.168.1.22 3389 192.168.0.1 3389
ip nat inside source static tcp 192.168.1.22 491 192.168.0.1 491
and test again.
i am already try that also not working.
configuration is correct or not.
Please conform.
try to add the 'extended' keyword to your static NAT translations:
ip nat inside source static tcp 192.168.1.22 3389 192.168.0.1 3389 extended
ip nat inside source static tcp 192.168.1.22 491 192.168.0.1 491 extended
i am found the answer guys,below add the command only port is opened.
ip nat inside source static tcp 192.168.1.9 3389 interface GigabitEthernet0/0 3389
access-list 100 permit tcp host 192.168.1.22 any
Looking at the configuration and comparing to several routers, I really do not see anything wrong here. Is
Can you do "sh ip nat translations | i 192.168.1.22" and do you see if there are translations for this entry?
