829 Dual SIM active active configuration
Holger Kunzek
i am looking for an active/active configuration for the ISR829 Dual SIM with dual modem router.
We would like to use "best RSSI" as the selector for the current provider.
Has anybody a sample configuration available, how to configure this  ?
Regrads, Holger
Hello Holger,
below is a sample configuration for a dual modem/dual SIM active/active setup for the 829.
Make sure the data profiles set under the cellular controllers match the ones you have configured.
version 15.6
service internal
hostname 829-DUAL-Modem
boot-start-marker
boot system flash:/ir800-universalk9-mz.SPA.156-3.M0a
boot-end-marker
no aaa new-model
ethernet lmi ce
service-module wlan-ap 0 bootimage autonomous
ignition off-timer 900
ignition undervoltage threshold 9
no ignition enable
no ip domain lookup
ip inspect WAAS flush-timeout 10
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid IR829-2LTE-EA-BK9 sn FGL2032219N
redundancy
notification-timer 120000
controller Cellular 0
lte sim data-profile 3 attach-profile 1
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
controller Cellular 1
lte sim data-profile 1 attach-profile 1
interface GigabitEthernet0
no ip address
shutdown
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface Wlan-GigabitEthernet0
no ip address
interface GigabitEthernet5
no ip address
shutdown
duplex auto
speed auto
interface Cellular0/0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation slip
load-interval 30
dialer in-band
dialer string lte
dialer-group 1
no peer default ip address
async mode interactive
routing dynamic
interface Cellular1/0
ip nat outside
encapsulation slip
load-interval 30
dialer in-band
dialer string lte
dialer-group 1
routing dynamic
interface Cellular0/1
no ip address
encapsulation slip
interface Cellular1/1
no ip address
encapsulation slip
interface wlan-ap0
no ip address
interface Vlan1
interface Async0
no ip address
encapsulation scada
interface Async1
no ip address
encapsulation scada
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map CELL_0 interface Cellular0/0 overload
ip nat inside source route-map CELL_1 interface Cellular1/0 overload
ip route 0.0.0.0 0.0.0.0 Cellular1/0
ip route 0.0.0.0 0.0.0.0 Cellular0/0
dialer-list 1 protocol ip permit
route-map CELL_0 permit 10
match ip address 1
match interface Cellular0/0
route-map CELL_1 permit 10
match ip address 1
match interface Cellular1/0
ipv6 ioam timestamp
access-list 1 permit 192.168.1.0
control-plane
line con 0
stopbits 1
line 1 2
stopbits 1
line 3
script dialer lte
no exec
transport preferred lat pad telnet rlogin lapb-ta mop udptn v120 ssh
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
rxspeed 150000000
txspeed 50000000
line 4
no activation-character
no exec
transport preferred none
transport input all
line 8
script dialer lte
no exec
rxspeed 150000000
txspeed 50000000
line 9
script dialer lte
no exec
transport input all
rxspeed 236800
txspeed 118000
line 15
no exec
rxspeed 236800
txspeed 118000
line 1/3 1/6
transport output none
stopbits 1
line vty 0 4
login
transport input none
no scheduler max-task-time
