866VAE - cant acces web pages from LAN
picusciscus
Hi everyone,
im fighting with Cisco 866VAE-K9 for few days. I have got ADSL2+ line in Cisco, i can ping anything from router (like 8.8.8.8 or www.google.com), test of connection in CCP runs successfully, but i cant acces web pages from LAN computers. From LAN i can ping to any IP adress in internet (like 8.8.8.8), but i cant ping or access domain names of web pages (like www.google.com). I know there is probably something wrong in my config, but after 2 days of googling i cant find where the problem is. Can anybody help?
Here is my running config:
Building configuration...
Current configuration : 8181 bytes
! Last configuration change at 11:31:15 UTC Fri Mar 6 2015 by admin
version 15.2
no service pad
hostname cisco_866vae
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 xx
enable password xx
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
wan mode dsl
ip port-map user-protocol--1 port tcp 3500
ip name-server 8.8.8.8
ip cef
no ipv6 cef
parameter-map type protocol-info yahoo-servers
 server name scs.msg.yahoo.com
 server name scsa.msg.yahoo.com
 server name scsb.msg.yahoo.com
 server name scsc.msg.yahoo.com
 server name scsd.msg.yahoo.com
 server name cs16.msg.dcn.yahoo.com
 server name cs19.msg.dcn.yahoo.com
 server name cs42.msg.dcn.yahoo.com
 server name cs53.msg.dcn.yahoo.com
 server name cs54.msg.dcn.yahoo.com
 server name ads1.vip.scd.yahoo.com
 server name radio1.launch.vip.dal.yahoo.com
 server name in1.msg.vip.re2.yahoo.com
 server name data1.my.vip.sc5.yahoo.com
 server name address1.pim.vip.mud.yahoo.com
 server name edit.messenger.yahoo.com
 server name messenger.yahoo.com
 server name http.pager.yahoo.com
 server name privacy.yahoo.com
 server name csa.yahoo.com
 server name csb.yahoo.com
 server name csc.yahoo.com
parameter-map type protocol-info msn-servers
 server name messenger.hotmail.com
 server name gateway.messenger.hotmail.com
 server name webmessenger.msn.com
parameter-map type protocol-info aol-servers
 server name login.oscar.aol.com
 server name toc.oscar.aol.com
 server name oam-d09a.blue.aol.com
crypto pki trustpoint TP-self-signed-2886901321
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2886901321
 revocation-check none
 rsakeypair TP-self-signed-2886901321
crypto pki certificate chain TP-self-signed-2886901321
 certificate self-signed 01
controller VDSL 0
class-map type inspect match-any SDM_BOOTPC
 match access-group name SDM_BOOTPC
class-map type inspect match-any ccp-cls-protocol-p2p
 match protocol edonkey signature
 match protocol gnutella signature
 match protocol kazaa2 signature
 match protocol fasttrack signature
 match protocol bittorrent signature
class-map type inspect match-all ccp-cls--1
 match access-group name all
class-map type inspect match-all ccp-cls--2
 match access-group name all1
class-map type inspect match-any ccp-cls-protocol-im
 match protocol ymsgr yahoo-servers
 match protocol msnmsgr msn-servers
 match protocol aol aol-servers
class-map type inspect match-any SDM_SSH
 match access-group name SDM_SSH
class-map type inspect match-any SDM_HTTPS
 match access-group name SDM_HTTPS
class-map type inspect match-all SDM_GRE
 match access-group name SDM_GRE
class-map type inspect match-any SDM_SHELL
 match access-group name SDM_SHELL
class-map type inspect match-any sdm-cls-access
 match class-map SDM_HTTPS
 match class-map SDM_SSH
 match class-map SDM_SHELL
class-map type inspect match-all sdm-access
 match class-map sdm-cls-access
 match access-group 101
policy-map type inspect ccp-policy-ccp-cls--1
 class type inspect ccp-cls--1
  pass
 class class-default
  drop
policy-map type inspect ccp-policy-ccp-cls--2
 class type inspect ccp-cls--2
  pass
 class class-default
  drop
zone security out
zone security in
zone-pair security sdm-zp-in-out source in destination out
 service-policy type inspect ccp-policy-ccp-cls--1
zone-pair security sdm-zp-out-in source out destination in
 service-policy type inspect ccp-policy-ccp-cls--2
interface Loopback0
 ip address 192.168.100.1 255.255.255.0
 zone-member security in
interface ATM0
 no ip address
 no atm ilmi-keepalive
interface ATM0.1 point-to-point
 pvc 8/48
  oam-pvc manage
  pppoe-client dial-pool-number 1
interface Ethernet0
 description $ETH-WAN$
 no ip address
 shutdown
 pppoe-client dial-pool-number 2
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface GigabitEthernet0
 no ip address
interface GigabitEthernet1
 description $ETH-WAN$$FW_OUTSIDE$
 ip address dhcp client-id GigabitEthernet1
 ip tcp adjust-mss 1412
 shutdown
 duplex auto
 speed auto
interface Vlan1
 description $FW_INSIDE$
 ip address 192.168.7.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
interface Dialer1
 no ip address
interface Dialer2
 description $FW_OUTSIDE$
 ip address negotiated
 ip mtu 1452
 ip nat outside
 zone-member security out
 encapsulation ppp
 dialer pool 1
 dialer-group 3
 ppp authentication chap pap callin
 ppp chap hostname o2
 ppp chap password 0 o2
 ppp pap sent-username o2 password 0 o2
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat source list 101 interface Dialer2 overload
ip nat inside source static tcp 192.168.7.39 3500 interface Dialer2 3500
ip nat inside source list 101 interface Dialer2 overload
ip nat inside source route-map MAP_ACL interface Dialer2 overload
ip route 0.0.0.0 0.0.0.0 Dialer2 permanent
ip route 192.168.2.0 255.255.255.0 192.168.7.3 permanent
ip access-list extended NAT_ACL
 deny   ip 192.168.0.0 0.0.0.255 192.168.0.0 0.0.255.255
 permit ip 192.168.0.0 0.0.0.255 any
ip access-list extended SDM_BOOTPC
 remark CCP_ACL Category=0
 permit udp any any eq bootpc
ip access-list extended SDM_GRE
 remark CCP_ACL Category=1
 permit gre any any
ip access-list extended SDM_HTTPS
 permit tcp any any eq 443
ip access-list extended SDM_SHELL
 permit tcp any any eq cmd
ip access-list extended SDM_SSH
 permit tcp any any eq 22
ip access-list extended all
 remark CCP_ACL Category=128
 permit ip any any
ip access-list extended all1
 permit ip any any
access-list 2 remark CCP_ACL Category=2
access-list 2 permit 192.168.7.0 0.0.0.255
access-list 101 remark CCP_ACL Category=128
access-list 101 permit ip any any
access-list 101 permit udp any any eq domain
access-list 101 permit udp any eq domain any
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
dialer-list 3 protocol ip permit
mac-address-table aging-time 15
route-map MAP_ACL permit 10
line con 0
 no modem enable
line aux 0
line vty 0 4
 exec-timeout 40 0
 password xxxxxxx
 transport input telnet ssh
 transport output telnet ssh
scheduler allocate 60000 1000
end
Peter Paluch
I would be happy to help but I have one question first: Your configuration contains a lot of cruft generated from SDM/CCP and I am not sure if any of that is really required by you. Do you believe you would be fine with having this entire configuration trimmed down and do just what's supposed to do (routing and NAT), and we had security measures added in later? Just by the way, I do not believe you need the zone-based firewall. In your simple setup with just a few inside/outside interfaces, it does not add any real value apart from making the configuration virtually unreadable. We can easily do the same with IP Inspect.
Best regards,
Peter
