867 VAE as PPPoE
I have being trying to config this router Cisco 867 VAE K9 for a while now.
since i am quite new to data, i m finding it a little difficut to configure the router.
I have a belkin router at home which i use for internet (pppoe)
I would like to know the basic requirement to setup this 867 VAE router as PPPoE.
Information i got from ISP.
username
password
VPI/VCI = 1/32
IP is DHCP from ISP
Enacapsulation is LLC
MTU 1492
I have checked quite few post, now in a confused state on how to set this up!!!
Can anyone provide me a min running config that would help me to setup internet using this router..?
here is what i have tried so far:
wan mode dsl
interface ATM0
ip address dhcp
no atm ilmi-keepalive
pvc 1/32
  ppp chap hostname XXX
  ppp chap password 0 YYYY
  ppp pap sent-username XXX password 0 YYYY
  encapsulation aal5snap
Is it mandatory to use a dailer interface???
ISP has said the encapsulation is LLC! does aal5snap help in this case?
Hope someone can help me on this.
Thanks.
Peter Paluch
Yes, it is mandatory to use Dialer interface. Your current configuration of the ATM interface appears to be partially correct. SNAP should be OK. Add these lines to your configuration please:
interface ATM0
  no ip address
  pvc 1/32
    no ppp chap hostname
    no ppp chap password
    no ppp pap sent-username
    pppoe-client dial-pool-member 1
    exit
  exit
interface Dialer1
  encapsulation ppp
  ppp chap password YYY
  ppp pap sent-username XXX password YYY
  dialer pool 1
  ip address negotiated
  ip mtu 1492
  ip tcp adjust-mss 1452
  ip nat outside
You may copy-paste them into your config.
Let us know if this worked for you please!
Best regards,
Peter
5 Replies 5
absolutly any input will be of great help guys..
Peter Paluch
interface ATM0
  no ip address
  pvc 1/32
    exit
  exit
interface Dialer1
  encapsulation ppp
  dialer pool 1
  ip mtu 1492
  ip nat outside
Best regards,
Peter
Thanks Peter....
It worked perfectly..
Exept for a minor change
pppoe-client dial-pool-member 1 was not there..
replaced it with pppoe-client dial-pool-number 1
What all debug should i run to study and understand the working of PPPoE..?
I apologize for getting back to this thread so late.
The PPPoE can be debugged using the following:
debug pppoe events
debug pppoe packets
Also, I would strongly advise you to read the RFC 2516 where the PPPoE is codified. The whole RFC has less than 18 pages and is easily readable. This document is the key to understanding what is inside the PPPoE.
Best regards,
Peter
