867VAE-K Router Setup
joelperks
Afternoon All
Ive been at this task for weeks on and off. What I thought was a simple setup has got me stumped. from the router CLI I can ping 8.8.8.8 but not from and ofthe hosts. Below is my router config, its now all over the place due to my constant fiddling with it.
Any Help would be good
Many thanks
Joel
! Last configuration change at 20:01:06 UTC Sun May 27 1900
version 15.5
no service pad
hostname R1
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$Y7rv$tnOv9CuFUqg5q/kJ2hs.P.
no aaa new-model
wan mode ethernet
ip dhcp pool media
import all
network 192.168.1.0 255.255.255.0
dns-server 203.12.160.36
default-router 192.168.1.10
no ip domain lookup
ip name-server 192.168.1.45
ip name-server 203.12.160.35
ip cef
no ipv6 cef
vpdn enable
vpdn-group 1
!Removed username
!controller VDSL 0
shutdown
!class-map match-all class-allow
policy-map type inspect p1
class class-default
pass
!interface Loopback0
ip address 10.10.2.10 255.255.255.0
ip nat outside
ip virtual-reassembly in
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0
ip address 10.10.100.100 255.255.255.0
shutdown
interface FastEthernet0
switchport access vlan 10
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
ip address 192.168.2.1 255.255.255.0
ip nat outside
duplex auto
speed auto
pppoe-client dial-pool-number 5
interface Virtual-Template1
no ip address
ppp pap sent-username *removed*
interface Virtual-Template10
ip unnumbered Loopback0
ip nat outside
interface Vlan1
ip address 10.10.10.10 255.255.255.0
ip nat inside
interface Vlan2
no ip address
interface Vlan5
ip address 192.168.3.10 255.255.255.0
ip nat inside
interface Vlan10
ip address 192.168.1.10 255.255.255.0
ip nat inside
interface Dialer5
ip address negotiated
ip mtu 1492
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 5
dialer-group 5
ppp authentication pap chap callin
ppp chap hostname *removed*
ppp chap password *removed*
ip forward-protocol nd
no ip http server
no ip http secure-server
!ip nat pool pool1 192.168.1.0 192.168.2.0 netmask 255.255.252.0
ip nat pool media 192.168.1.0 192.168.1.254 netmask 255.255.255.0
ip nat inside source list 1 interface Dialer5 overload
ip nat inside source list acl1 pool pool1
ip route 0.0.0.0 0.0.0.0 Dialer5
dialer-list 5 protocol ip permit
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 10 permit any
gateway
timer receive-rtp 1200
!scheduler allocate 60000 1000
end
R1#
the config looks odd. You have an IP address assigned to interface GigabitEthernet1, but the interface is also bound to dialer 5.
Is this router behind an ISP modem/router ?
*edit* removed the IP Address on g/1,  still not getting pings out.
Gday
Yea this network is sitting behind the ISP which is FTTP (fiber to the premise). I'm not sure what they are using or settings.
I'll remove the giga/1 ip address binding
Joel
