867VAE-K9 DHCP ack messages not being recieved
ObsessedLime
Hi all,
I am just beginning my first homelab and have been trying to setup a Cisco 867VAE-K9 router, specifically I am trying to get DHCP working, so I can setup the switch I have.
prior I had been trying to setup with vlan1, but had swapped to test that wasn't the issue.
So far on the client end, it receives/sends everything but the Acknowledgement message:
I can confirm its not a client side issue, as I have tried a range of different devices, and on the routers side, it is sending ACK messages, Also when I set the client to a static ip, routing works fine.
(dhcp server statistics ( config under) )
Memory usage 262289
Address pools 2
Database agents 0
Automatic bindings 0
Manual bindings 0
Expired bindings 27
Malformed messages 0
Secure arp entries 0
Message Received
BOOTREQUEST 0
DHCPDISCOVER 72
DHCPREQUEST 218
DHCPDECLINE 0
DHCPRELEASE 0
DHCPINFORM 0
Message Sent
BOOTREPLY 0
DHCPOFFER 72
DHCPACK 190
DHCPNAK 12
Here is my config:
Current configuration : 1459 bytes
! Last configuration change at 09:43:00 UTC Wed Feb 6 2036
version 15.1
no service pad
hostname router1
boot-start-marker
boot-end-marker
no aaa new-model
wan mode dsl
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp pool TEST
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 1.1.1.1
lease 7
ip dhcp pool MAIN
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 8.8.8.8
lease 7
controller VDSL 0
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
switchport access vlan 10
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 60000 1000
end
Royalty
Hi @ObsessedLime,
Config-wise, everything looks OK to me. Would you be able to complete the following steps please?
  1. Launch a console/SSH session to the router and perform the following commands in privileged exec mode / enable mode
    1. Disconnect PC from Fa0
    2. clear ip dhcp binding *
    3. debug ip dhcp server packet
    4. debug ip dhcp server event
    5. Restart PC
    6. Reconnect cable from PC to the 867 Fa0 port, do this after reboot at some point during BIOS splash screen / system POST
If you are accessing the CLI via SSH/Telnet you may also need to issue terminal monitor from enable mode (privileged exec) as well in order to see the debug output. If you are connected via the console port it is not necessary. Can you paste the output here or in a .txt file please?
Can I just confirm that your client devices are patched directly into FastEthernet0? Finally, you had the same problem when using VLAN 1? Can you post an output of show version too please?
Thanks!
