Showing results forĀ
Search instead forĀ
Did you mean:Ā
867vae-k9 IOS after ios update then factory reset, cant login
transmit1
Router is Cisco 867vae-k9
Cisco CP Express was updated toverion 3.5 ok
IOS was c860vae-advsecurityk9-mz.151-4M5.bin
Factorry reset works aok and rests the password to the defaut
one-time cisco/cisco, (which works.)
Cisco CP web interfaces also ok, but gives message that some secutity features are not enable because of the old firmware.
So, then IOS was updated to c860vae-advsecurityk9-mz.157-3.M.bin
Then Factory reset
the  serial console, boots ok showing the new IOS version
and displaying Cisco CP onetime usename cisco/cisco message
but get
% Login invalid
what can I do to get back in, I have tried factory reset several times.?
transmit1
I found the problem,
looks like the new IOs requires the factory reset button to be help for much longer than 10 sec.
I help it till ##################################
########################################### [OK]
and the default login was reste to cisco/cisco
transmit1
