Where do we apply Static NAT, Dynamic NAT and Dynamic NAT Overload in the real scenario basis?
Ketan Bheda
Hi All,
Can you please help me out where do Static, Dynamic and Dynamic NAT Overload are applied in real scenario?
bersoare
Hello Ketan,
Static nat is usually configured when you need to provide outside to inside reachability for a given host. For example, a web server in your DMZ that will be accessed from the internet.
The only application i have seen of Dynamic nat is when you have overlapping ip addresses. In that particular case, we had to translate a 192.168.0.0/24 network into another range of IPs.
Last, but not least, Overload allows you to translate multiple internal IPs into a single outside IP. Sometimes also called PAT. This is often used for providing internet access in a border router or firewall.
Hi Bersoare,
Can you please explain me in detail what is the overlapping IP Address?
Also can you be more clear about the scenario for using Static NAT?
