867VAE K9
nihit-tandon
pls let me know whether 867 VAE K9 supports HSRP or not , As per data sheet no where it says HSRP support.
InayathUlla Sharieff
Nihit,
860VAE does not support HSRP/VRRP.
None of the 860 have any FHRPs, this is one of the differentiators to go up to
880/890.
Inayath
**********Please rate useful posts and remember to mark any solved questions as answered. Thank you.
sorry to bring this back from the dead, but as this is the top result from Google I thought I had better add to it. Just had to check this for a client and apparently they have HSRP and VRRP.
Haven't actually tried to configure it yet, but it seems I'm going to get another router and find out.
867vae-k9#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
867vae-k9(config)#int vl1
867vae-k9(config-if)#st
867vae-k9(config-if)#standby ?
  <0-255>         group number
  authentication  Authentication
  delay           HSRP initialisation delay
  follow          Name of HSRP group to follow
  ip              Enable HSRP IPv4 and set the virtual IP address
  mac-address     Virtual MAC address
  mac-refresh     Refresh MAC cache on switch by periodically sending packet
                  from virtual mac address
  name            Redundancy name string
  preempt         Overthrow lower priority Active routers
  priority        Priority level
  redirect        Configure sending of ICMP Redirect messages with an HSRP
                  virtual IP address as the gateway IP address
  timers          Hello and hold timers
  track           Priority tracking
  use-bia         HSRP uses interface's burned in address
  version         HSRP version
867vae-k9(config-if)#vrrp
867vae-k9(config-if)#vrrp ?
  <1-255>  Group number
867vae-k9(config-if)#do sh ver
Cisco IOS Software, C860 Software (C860VAE-ADVSECURITYK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 21-Mar-12 00:04 by prod_rel_team
ROM: System Bootstrap, Version 15.1(4r)M2, RELEASE SOFTWARE (fc1)
867vae-k9 uptime is 1 day, 22 hours, 18 minutes
System restarted at 18:39:34 GMT Wed Feb 25 2015
System image file is "flash:c860vae-advsecurityk9-mz.151-4.M4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 867VAE-K9 (BCM6368) processor (revision 0.3) with 234496K/26624K bytes of memory.
Processor board ID GMK114800XV
1 DSL controller
1 Ethernet interface
4 FastEthernet interfaces
2 Gigabit Ethernet interfaces
1 ATM interface
1 Virtual Private Network (VPN) Module
255K bytes of non-volatile configuration memory.
57344K bytes system flash allocated
