867VAE-W-E-K9 router at home
Dear All,
Am using 867VAE-W-E-K9 router at home for ADSL purpose and WiFi. But the Wifi singnal is very very low and i don't use any other device with wifi enabled. Is there any way that i can improve the signal strength?? Kindly share your knowledge.
Britto Vimalraj
keglass
Level 7
Level 7
Britto,
I recommend you also post this question to the Cisco Support Community for more information and feedback. You may also find a similar question and response that would be helpful for your situation.
https://supportforums.cisco.com/search/site/867VAE-W-E-K9?f[0]=is_top_level%3A5411
I hope this helps. Thank you for participating in the community.
Kelli Glass
Moderator for Cisco Customer Communities
