871 configuration
msgulotta
I need a sample configuration for connecting a 871 to a cable modem. I am using DHCP on the WAN port but can not get internet connectivity from the LAN ports.
globalnettech
Level 5
Level 5
Hello Mark,
have a look at the link below. If possible, can you post the configuration you have so far ? You might be missing something...
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/85x87x/857swcg/eng/pt2/sampconf.htm
GNT
