871 w/ ADV Security & QoS not matching
I have a Cisco 871 router with Advanced Security and have setup QoS, since I can't match dcsp I have used an ACL with my phone network (attached to this router is a Cisco SF300 running as a Layer 3 switch handling the VLANs).
class-map match-any voice-traffic
match access-group name voice-traffic
policy-map voice-policy
class voice-traffic
  priority 1000
class class-default
  fair-queue
policy-map shaper
class class-default
  shape average 3000000 30000 0
  service-policy voice-policy
ip access-list extended voice-traffic
permit ip 10.10.51.0 0.0.0.255 any
interface FastEthernet4
ip address 111.111.111.111 255.255.255.248
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
crypto map ipsec
service-policy output shaper
Here's the sh policy-map interface
FastEthernet4
  Service-policy output: shaper
    Class-map: class-default (match-any)
      1750843 packets, 335256512 bytes
      5 minute offered rate 20000 bps, drop rate 0 bps
      Match: any
      Traffic Shaping
           Target/Average   Byte   Sustain   Excess    Interval  Increment
             Rate           Limit  bits/int  bits/int  (ms)      (bytes)
          3000000/3000000   3750   30000     0         10        3750
        Adapt  Queue     Packets   Bytes     Packets   Bytes     Shaping
        Active Depth                         Delayed   Delayed   Active
        -      0         1750769   335180439 99458     90434169  no
      Service-policy : voice-policy
        Class-map: voice-traffic (match-any)
          2 packets, 124 bytes
          5 minute offered rate 0 bps, drop rate 0 bps
          Match: access-group name voice-traffic
            5 minute rate 0 bps
          Queueing
            Strict Priority
            Output Queue: Conversation 136
            Bandwidth 1000 (kbps) Burst 25000 (Bytes)
            (pkts matched/bytes matched) 0/0
            (total drops/bytes drops) 0/0
          1750842 packets, 335256442 bytes
          Match: any
          Queueing
            Flow Based Fair Queueing
            Maximum Number of Hashed Queues 128
        (total queued/total drops/no-buffer drops) 0/59/0
There should be WAY more packets than 2
9 Replies 9
Peter Paluch
Hi Christie,
I see you are using a crypto map on your Fa4 interface. Did you configure the qos pre-classify in the crypto map? If not, the service-policy can only see the packets after being IPsec-encapsulated, not recognizing the private IP addresses anymore.
Best regards,
Peter
Not sure if it matters but the phone traffic is not going over the VPN tunnel.
I checked anyways and I do not have the feature to add qos pre-classify to my crypto map. I am on version 12.4(15)
Hi Christie,
Oh, I see. Okay.
The second thing to check is the NAT - again, I see that the Fa4 is a NAT-outside interface. According to the following document:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080133ddd.shtml
the queueing is done as the very last step in the inside-to-outside direction, meaning that the service-policy will again see packets after they have been NATted - so again, the ACL in the corresponding class-map does not apply.
Solution here can get more complicated because you may be performing N:1 NAT (i.e. PAT) and so the global address is not indicative of the VoIP traffic anymore.
I wonder - what IOS feature set are you running? Can you post the output that shows when you enter a class-map and enter the match ? and set ? commands and question marks? I would like to see what other choices we have on your IOS.
Best regards,
Peter
Advanced Security -
c870-advsecurityk9-mz.124-15.T7.bin
Here's the match?
  access-group         Access group
  any                  Any packets
  class-map            Class map
  cos                  IEEE 802.1Q/ISL class of service/user priority values
  destination-address  Destination address
  discard-class        Discard behavior identifier
  flow                 Flow based QoS parameters
  fr-de                Match on Frame-relay DE bit
  fr-dlci              Match on fr-dlci
  input-interface      Select an input interface to match
  ip                   IP specific values
  mpls                 Multi Protocol Label Switching specific values
  not                  Negate this match result
  packet               Layer 3 Packet length
  precedence           Match Precedence in IP(v4) and IPv6 packets
  protocol             Protocol
  qos-group            Qos-group
  source-address       Source address
  vlan                 VLANs to match
Set is not recognized under class-map.
Hi Christie,
Of course, set is in the policy-map... Aaargh, how could I have missed that?
Anyway, in your first post, you indicated you can not match DSCP. Why? Do you believe your IP phone is not generating DSCP-marked packets? That would be the easiest thing here, as the DSCP marking is easily recognizable.
Best regards,
Peter
I dont have the option for set under the policy-map
I can't match DSCP on the router, it's not an option in advanced security, only advanced IP.
Christie,
The set option is available in a class section of a policy-map. Try entering a policy-map and enter either an existing class or enter the class-default class and try the set command there.
But is the Advanced Security IOS really so limited? The DSCP should be available in a class-map using match ip dscp command. Is is truly unavailable?
Best regards,
Peter
It appears that way, I believe the feature information says the advanced IP has more QoS options.
Here is what I see under class under policy-map when I do a ?
  bandwidth        Bandwidth
  compression      Activate Compression
  drop             Drop all packets
  exit             Exit from class action configuration mode
  log              Log IPv4 and ARP packets
  netflow-sampler  NetFlow action
  no               Negate or set default values of a command
  police           Police
  priority         Strict Scheduling Priority for this Class
  queue-limit      Queue Max Threshold for Tail Drop
  service-policy   Configure Flow Next
  set              Set QoS values
  shape            Traffic Shaping
and this is set ?
  atm-clp        Set ATM CLP bit to 1
  cos            Set IEEE 802.1Q/ISL class of service/user priority
  fr-de          Set FR DE bit to 1
  ip             Set IP specific values
  mpls           Set MPLS specific values
  precedence     Set precedence in IP(v4) and IPv6 packets
  qos-group      Set QoS Group
Christie,
I apologize for being so insistent, but can you perhaps enter a class-map again and try the match ip ? command? At my router, it produces this (though admittedly, I do not run AdvSec):
R1(config-cmap)# match ip ?
   dscp        Match IP DSCP (DiffServ CodePoints)
   precedence  Match IP precedence
   rtp         Match RTP port nos
Best regards,
Peter
