Cannot access internet using 887va sec and plusnet (BT) VDSL service
Jinesh Patel
Hi All,
Trying to get my 887va setup for VDSL but can't get to anything on the net -
Controller VDSL 0
vpdn enable
vpdn-group 1
interface ethernet0
no ip address
ip tcp adjust-mss 1452
shutdown
interface ethernet0.101
encapsulation dot1q 101
ip virtual-reassembly in
pppoe enable group global
pppoe-client dial-pool number 1
exit
interface fa1
switchport access vlan 1
no ip address
interface fa2
no ip address
interface fa3
swithcport access vlan 1
no ip address
interface atm0
no ip address
shutdown
interface d0
no ip address
interface d1
description PlusNet Fibre
ip address negotiated
no ip unreachables
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname myusername
ppp chap password 0 route
ppp pap sent-username myusername password 0 route
ppp ipcp dns request
no cdp enable
interface vlan1
ip address 10.10.5.1 255.255.255.128
ip nat inside
ip nat inside source list 101 interface d1 overload
access-list 101 permit ip 10.10.5.0 0.0.0.127 any
ALTHOUGH i'm synching (at least, i think i am) -
sh controller vdsl 0
Controller VDSL 0 is UP
Daemon Status: Up
XTU-R (DS) XTU-C (US)
Chip Vendor ID: 'BDCM' 'BDCM'
Chip Vendor Specific: 0x0000 0xA39D
Chip Vendor Country: 0xB500 0xB500
Modem Vendor ID: 'CSCO' ' '
Modem Vendor Specific: 0x4602 0x0000
Modem Vendor Country: 0xB500 0x0000
Serial Number Near: FCZ1616C1LH 887VA-SE 15.2(1)T
Serial Number Far:
Modem Version Near: 15.2(1)T
Modem Version Far: 0xa39d
Modem Status: TC Sync (Showtime!)
DSL Config Mode: AUTO
Trained Mode: G.993.2 (VDSL2) Profile 17a
TC Mode: PTM
Selftest Result: 0x00
DELT configuration: disabled
DELT state: not running
Trellis: ON ON
SRA: disabled disabled
SRA count: 0 0
Bit swap: enabled enabled
Bit swap count: 160 115
Line Attenuation: 0.0 dB 0.0 dB
Signal Attenuation: 0.0 dB 0.0 dB
Noise Margin: 6.2 dB 6.0 dB
Attainable Rate: 49152 kbits/s 17794 kbits/s
Actual Power: 13.9 dBm 6.9 dBm
Per Band Status: D1 D2 D3 U0 U1 U2 U3
Line Attenuation(dB): 13.1 40.0 49.5 4.9 28.3 40.4 N/A
Signal Attenuation(dB): 13.1 40.0 49.5 4.9 27.5 39.4 N/A
Noise Margin(dB): 6.1 6.3 6.1 5.9 6.0 6.0 N/A
Total FECS: 0 5
Total ES: 11 0
Total SES: 2 0
Total LOSS: 0 0
Total UAS: 0 0
Total LPRS: 0 0
Total LOFS: 0 0
Total LOLS: 0 0
Full inits: 1
Failed full inits: 0
Short inits: 0
Failed short inits: 0
Firmware Source File Name (version)
VDSL embedded VDSL_LINUX_DEV_01212008 (1)
Modem FW Version: 110331_1212-4.02L.03.A2pv6C032b.d23f
Modem PHY Version: A2pv6C032b.d23f
DS Channel1 DS Channel0 US Channel1 US Channel0
Speed (kbps): 0 48487 0 17779
SRA Previous Speed: 0 0 0 0
Reed-Solomon EC: 0 0 0 5
CRC Errors: 0 482 0 0
Header Errors: 0 45 0 0
Interleave (ms): 0.00 0.00 0.00 0.00
Actual INP: 0.00 0.00 0.00 0.00
Do you have any idea what might be wrong?
I've just changed from ADSL where the config was working perfectly.  I've still got to re-add my remote and P2P vpn config and EIGRP configs back in but can't as i can't even get this right :-(
Your help is much needed and appreciated (in advance)
J
Your config seems okay, But can you try and tweek it a little to this below?
interface ethernet0
no ip address
no shut
pppoe enable
interface dialer 1
no ip unreachables
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname xxxx
ppp chap password xxxx
no cdp enable
sh ip int bri | in up
deb ppp authentication
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
7 Replies 7
jawad-mukhtar
Level 4
Level 4
you default route is missing
ip route 0.0.0.0 0.0.0.0 dialer 1
also configure
ip routing
*** Do Rate all Helpful Posts***
Jawad
Thanks for your response
I did have the ip route 0.0.0.0/0 d1 command applied but did not show it, apologies.
Here are the current errors that i see -
1 - Initial Error -
Mar 17 17:33:19.395:  Sending PADI: Interface = Ethernet0.101
Mar 17 17:33:19.415: PPPoE 0: I PADO  R:0030.8800.0005 L:a44c.1102.2e2c 101 Et0.101
Mar 17 17:33:21.443:  PPPOE: we've got our pado and the pado timer went off
Mar 17 17:33:21.443: OUT PADR from PPPoE Session
Mar 17 17:33:21.487: PPPoE 1743: I PADS  R:0030.8800.0005 L:a44c.1102.2e2c 101 Et0.101
Mar 17 17:33:21.487: IN PADS from PPPoE Session
Mar 17 17:33:21.487: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
Mar 17 17:33:21.487: PPPoE: Virtual Access interface obtained.
Mar 17 17:33:21.491: PPPoE : encap string prepared
Mar 17 17:33:21.491: [0]PPPoE 1743: data path set to PPPoE Client
Mar 17 17:33:21.495: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
Mar 17 17:33:24.255: PPPoE 1743: I PADT  R:0030.8800.0005 L:a44c.1102.2e2c 101 Et0.101
Mar 17 17:33:24.255:  PPPoE : Shutting down client session
Mar 17 17:33:24.255: [0]PPPoE 1743: O PADT  R:0030.8800.0005 L:a44c.1102.2e2c Et0.101
Mar 17 17:33:24.255: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
Mar 17 17:33:24.259: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
2 - Plusnet said the password was incorrect so after changing it (adding in the actual password rather than 0 as above) -
Router#debug pppoe even
PPPoE protocol events debugging is on
Router#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Mar 17 17:51:50.307:  padi timer expired
Mar 17 17:51:50.307:  Sending PADI: Interface = Ethernet0.101...
Success rate is 0 percent (0/5)
Router#
Mar 17 18:11:43.995:  padi timer expired
Mar 17 18:11:43.995:  Sending PADI: Interface = Ethernet0.101
Router#sh pppoe sess
     1 client session
Uniq ID  PPPoE  RemMAC          Port                    VT  VA         State
           SID  LocMAC                                      VA-st      Type
    N/A   4058  0030.8800.0005  Et0.101                 Di1 N/A        PADISNT
                a44c.1102.2e2c  VLAN: 101
Thanks for your help
interface ethernet0
no ip address
no shut
pppoe enable
interface dialer 1
no ip unreachables
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
res
Paul
Thanks.
Kind Regards
Paul
Paul,
I'm going through the differences now betwen your config and mine to decipher what the difference is.  But in the meant time, whatever the difference, it's WORKING
I'm adding a sh run of my config which takes account of the changes you asked me to make and i was wondering what you think the problem might be.
Router#sh run
Building configuration...
Current configuration : 1670 bytes
! Last configuration change at 19:42:01 UTC Mon Mar 18 2013
version 15.2
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip cef
no ipv6 cef
vpdn enable
vpdn-group 1
license udi pid CISCO887VA-SEC-K9 sn FCZ1616C1LH
vtp domain test.local
vtp mode transparent
controller VDSL 0
interface Ethernet0
no ip address
interface Ethernet0.101
encapsulation dot1Q 101
pppoe-client dial-pool-number 1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip nat inside
interface Dialer1
no ip unreachables
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname test@test.com
ppp chap password 0 test
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 101 permit ip any any
control-plane
line con 0
line aux 0
line vty 0 4
login
transport input all
end
Router#
I'm now going to add the rest of my config (inter vlan routing and remote and PTP VPN so imight come back to you if i run into any more issues.
With much delight, I thank you :-)
hello
glad to hear its working.
The two things i could see was:
1) the main eth0 interface was shutdown
2) your ppp authentication
res
Paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
BT Infinity supports RFC4638 (MTU greater than 1492 over PPPoE) so you may not require these lines:
ip mtu 1492
I have successfully configured both a Cisco 867VAE and a 1921/EHWIC-VA-DSL with a default MTU of 1500 on BT Infinity so it may also work on the 887VA.
BT do support RFC4638 however you need to configure your side to negotiate a bigger MRU.  You can then remove the 'ip mtu 1492' and 'ip tcp adjust-mss 1452' commands:
interface Ethernet0
mtu 1508
no ip address
pppoe-client ppp-max-payload 1500
cisco-887va#sho ppp interface virtual-Access 4
PPP Serial Context Info
Interface        : Vi4
PPP Serial Handle: 0x63000001
PPP Handle       : 0xCA000001
SSS Handle       : 0xD8000002
AAA ID           : 13
Access IE        : 0x8B000001
SHDB Handle      : 0x0
State            : Up
Last State       : Binding
Last Event       : LocalTerm
PPP Session Info
Interface        : Vi4
PPP ID           : 0xCA000001
Phase            : UP
Stage            : Local Termination
Peer Name        : bras-red11.pe
Peer Address     : 217.32.145.10
Control Protocols: LCP[Open] IPCP[Open]
Session ID       : 1
AAA Unique ID    : 13
SSS Manager ID   : 0xD8000002
SIP ID           : 0x63000001
PPP_IN_USE       : 0x11
Vi4 LCP: [Open]
Our Negotiated Options
Vi4 LCP:    MagicNumber 0x4C145BF4 (0x05064C145BF4)
Peer's Negotiated Options
Vi4 LCP:    MRU 1500 (0x010405DC)
Vi4 LCP:    AuthProto CHAP (0x0305C22305)
Vi4 LCP:    MagicNumber 0x0D2B90C7 (0x05060D2B90C7)
Vi4 IPCP: [Open]
Vi4 IPCP:    Address x.x.x.x (0xxxxxxx)
Vi4 IPCP:    PrimaryDNS 213.120.234.74 (0x8106D578EA4A)
Vi4 IPCP:    SecondaryDNS 213.120.234.66 (0x8306D578EA42)
Vi4 IPCP:    Address 217.32.145.10 (0x0306D920910A)
Cheers
Andy
