871W - Translation to an internal Web server
tdholwerda
We're attempting to allow access to our internal web server from the Internet.  Unfortunately, we're not very familiar with the 871W as we typically install ASA's but this is a pre-existing device.  Below is the config.  Can someone please point out what we have misconfigured?  BTW - I did modify the actual external IP address to protect any holes that may exist with this configuration...
Many thanks!
Troy
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname solcenter
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
no logging monitor
enable secret 5 $1$cRwn$SHl6w1Wq0E23oD6YQXitJ1
no aaa new-model
clock timezone PCTime 0
crypto pki trustpoint TP-self-signed-3906865615
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3906865615
revocation-check none
rsakeypair TP-self-signed-3906865615
crypto pki certificate chain TP-self-signed-3906865615
certificate self-signed 01
  3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33393036 38363536 3135301E 170D3032 30333031 30303331
  34375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 39303638
  36353631 3530819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B663 81A81339 D1197089 6C5CC8BA 72B4EBCF ABC7EAFA D2697B3A 6A35A2AD
  17F73845 86AFF234 B4019C65 2D5BC160 0ABF665A 6BAC94F4 0ABB073C CA1A20E8
  02DE81D2 1581B7BB 4C7BF0C3 DB65D1C9 B74D61F9 2889673D 520AD61C A8886EF0
  D6116219 4F7B339D F8F14769 ADDF7CD2 27C4C1BA 817AE593 40B53C23 54515687
  425B0203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
  551D1104 1B301982 17736F6C 63656E74 65722E73 6F6C6365 6E746572 2E6F7267
  301F0603 551D2304 18301680 14733E00 C0529604 53EE7DD5 CA1D6222 92E6B105
  3F301D06 03551D0E 04160414 733E00C0 52960453 EE7DD5CA 1D622292 E6B1053F
  300D0609 2A864886 F70D0101 04050003 81810052 4A6AE1B7 6B69C819 17DFEA57
  D0DFF35A 29CC2CF8 74F6A882 5467B06B 4576B76B C92BB2A4 02D67074 67DAFD91
  CE577251 70679759 B98838B3 126208D6 911198FF 16277E84 7F5C2BD9 A005EB8F
  663FD427 6C18CDEE 9A83095A DEC16E36 C5D3FD4D C94641BF AC84B1F3 B1AAEF2A
  2B50281F 2EC28FC8 0EE1CD2D 62F73FE3 ED9E05
        quit
no ip source-route
ip cef
ip port-map user-protocol--1 port tcp 3389
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip bootp server
ip domain name solcenter.org
ip name-server 1.1.1.5
ip name-server 1.1.1.6
username admin privilege 15 secret 5 $1$e1A7$kWAsDBWpyIn4aAu/C.fYa1
username cetech privilege 15 secret 5 $1$XBzN$4gGA6FAQYPC2qIRRQV4Xt0
archive
log config
  hidekeys
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
class-map type inspect match-all sdm-nat-http-4
match access-group 107
match protocol http
class-map type inspect match-all sdm-nat-http-5
match access-group 108
match protocol http
class-map type inspect match-all sdm-nat-http-6
match access-group 106
match protocol http
class-map type inspect match-all sdm-nat-http-1
match access-group 102
match protocol http
class-map type inspect match-all sdm-nat-user-protocol--1-1
match access-group 103
match protocol user-protocol--1
class-map type inspect match-all sdm-nat-http-2
match access-group 105
match protocol http
class-map type inspect match-all sdm-nat-smtp-1
match access-group 101
match protocol smtp
class-map type inspect match-all sdm-nat-http-3
match protocol http
class-map type inspect match-any sdm-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol h323
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp extended
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all sdm-insp-traffic
match class-map sdm-cls-insp-traffic
class-map type inspect match-any sdm-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-all sdm-icmp-access
match class-map sdm-cls-icmp-access
class-map type inspect match-all sdm-invalid-src
match access-group 100
class-map type inspect match-all sdm-protocol-http
match protocol http
class-map type inspect match-all sdm-nat-https-1
match access-group 104
policy-map type inspect sdm-permit-icmpreply
class type inspect sdm-icmp-access
  inspect
class class-default
  pass
policy-map type inspect sdm-pol-NATOutsideToInside-1
class type inspect sdm-nat-smtp-1
  inspect
class type inspect sdm-nat-http-1
  inspect
class type inspect sdm-nat-user-protocol--1-1
  inspect
class type inspect sdm-nat-https-1
  inspect
class type inspect sdm-nat-http-2
  inspect
class type inspect sdm-nat-http-3
  inspect
class type inspect sdm-nat-http-4
  inspect
class type inspect sdm-nat-http-5
  inspect
class type inspect sdm-nat-http-6
  inspect
class class-default
policy-map type inspect sdm-inspect
class type inspect sdm-invalid-src
  drop log
class type inspect sdm-insp-traffic
  inspect
class type inspect sdm-protocol-http
  inspect
class class-default
class class-default
zone security out-zone
zone security in-zone
zone-pair security sdm-zp-self-out source self destination out-zone
service-policy type inspect sdm-permit-icmpreply
zone-pair security sdm-zp-NATOutsideToInside-1 source out-zone destination in-zone
service-policy type inspect sdm-pol-NATOutsideToInside-1
zone-pair security sdm-zp-out-self source out-zone destination self
zone-pair security sdm-zp-in-out source in-zone destination out-zone
service-policy type inspect sdm-inspect
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $FW_OUTSIDE$$ES_WAN$
ip address 1.1.1.2 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
zone-member security out-zone
ip route-cache flow
duplex auto
speed auto
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 192.168.1.10 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
zone-member security in-zone
ip route-cache flow
ip tcp adjust-mss 1452
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 1.1.1.2
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source static tcp 192.168.1.205 80 interface FastEthernet4 80
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 100 permit ip 1.1.1.0 0.0.0.7 any
access-list 101 remark SDM_ACL Category=0
access-list 101 permit ip any host 192.168.1.2
access-list 102 remark SDM_ACL Category=0
access-list 102 permit ip any host 192.168.1.2
access-list 103 remark SDM_ACL Category=0
access-list 103 permit ip any host 192.168.1.2
access-list 104 remark SDM_ACL Category=0
access-list 104 permit ip any host 192.168.1.2
access-list 105 remark SDM_ACL Category=0
access-list 105 permit ip any host 192.168.1.205
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
password 7 1040592E550500020940
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
cadet alain
Did you change the internal IPs too ?
match protocol http
access-list 102 permit ip any host 192.168.1.2  Is this a typo ? it should be x.x.x.205
Also could you change the external port on Wan to 8080 in your NAT command and add this
ip port-map tcp http 8080
Alain
