876 adsl wan problems
Hi, i'm having problems with a cisco 876 i got to study CCNA on, no matter what i've tried i can't get it to connect to the wan instead of using my talktalk router.
talktalk settings are
VCI 0/38
PPPoA CHAP VCMUX
Anyone got any ideas where i could find a config that would help me?
John Blakley
See if this helps you out:
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/pppoanat.html
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Hi thanks, i've tried it and it's not worked, i tried another one i found online too, i'm thinking the interface might be broken as it shows line protocol down
ATM0.1 is initializing, line protocol is down
  Hardware is MPC ATMSAR (with Alcatel ADSL Module)
  MTU 4470 bytes, BW 4608 Kbit, DLY 80 usec,
  Encapsulation ATM
  0 packets input, 0 bytes
  0 packets output, 0 bytes
  0 OAM cells input, 0 OAM cells output
  AAL5 CRC errors : 0
  AAL5 SAR Timeouts : 0
  AAL5 Oversized SDUs : 0
     2220563832 packets input, 2220035864 bytes
     2220563880 packets output, 2147724396 bytes
Gateway#show int dialer 0
Dialer0 is up (spoofing), line protocol is up (spoofing)
  Hardware is Unknown
  Description: Outside Interface
  Internet address will be negotiated using IPCP
  MTU 1500 bytes, BW 56 Kbit, DLY 20000 usec,
  Encapsulation PPP, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 1 seconds on reset
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 00:19:48
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 42 kilobits/sec
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
Gateway#sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  up                    down
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    down
BRI0                       unassigned      YES NVRAM  administratively down down
BRI0:1                     unassigned      YES unset  administratively down down
BRI0:2                     unassigned      YES unset  administratively down down
ATM0                       unassigned      YES manual initializing          down
ATM0.1                     unassigned      YES unset  initializing          down
Vlan1                      192.168.1.48    YES NVRAM  up                    up
NVI0                       unassigned      NO  unset  up                    up
Dialer0                    unassigned      YES NVRAM  up                    up
Virtual-Access1            unassigned      YES unset  up                    up
Gateway#sh run
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly
load-interval 30
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
dsl operating-mode adsl2+
dsl lom 250
hold-queue 224 in
interface ATM0.1 point-to-point
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no snmp trap link-status
pvc 0/38
  vbr-nrt 756 756 1
  tx-ring-limit 3
interface Vlan1
ip address 192.168.1.48 255.255.255.0
ip nat inside
interface Dialer0
description Outside Interface
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1432
ip flow ingress
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
load-interval 30
dialer pool 1
dialer-group 2
no cdp enable
ppp max-bad-auth 3
ppp lcp predictive
ppp lcp delay 1
ppp authentication chap pap callin
ppp chap hostname xxxxxxxx@talktalk.net
ppp chap password 0 xxxxxxx
ppp pap sent-username xxxxxx@talktalk.net password 0 xxxxxxxxx
ppp ipcp predictive
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 0.0.0.0 255.255.255.0
dialer-list 1 protocol ip permit
Gateway#sh startup-config
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
ip nat outside
pvc 0/38
dsl operating-mode auto
interface Vlan1
ip nat inside
interface Dialer0
ip mtu 1432
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname xxxxx@talktalk.net
ppp pap sent-username 0xxxxxx@talktalk.net password 0 xxxxxxxx
