877 and bandwidth parameter change after reload
j.merchut
Does anybody had a problem with bandwidth parameter change after reaload?
I have a Cisco 877 router with AdvIPSer software and such a configuration considering ATM interface:
interface ATM0
bandwidth 256
no ip address
load-interval 30
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
ip address 10.0.0.1 255.255.255.252
no ip redirects
no ip unreachables
no snmp trap link-status
pvc 0/35
vbr-nrt 320 320 1
oam-pvc manage 5
oam retry 3 5 1
encapsulation aal5mux ip
After reload bandwidth parameter changes to 320 every time. Why?
Is it normal situation for this model?
Best regards,
JM
j-block
Level 4
Level 4
In general, all routing protocol and packets sourced by the router are serviced with a higher degree of priority even if these packets fall into the default queue.
Try:
http://www.cisco.com/en/US/products/ps6558/products_ios_technology_home.html
OK, but my problem is - why bandwidth parameter is changing after reload, why ie. OSPF has to recalculate its metric because of changing bandwidth parameter?
