show ip bgp
Danilo Dy
I need some light about the "show ip bgp" output in one of my router.
RT2# show ip bgp
BGP table version is 2, local router ID is 192.168.0.253
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
* i192.168.0.0/20 192.168.0.252 0 100 0 i
* i 192.168.0.254 0 100 0 i
*> 192.168.0.141 20 32768 i
RT2#
192.168.0.141 is not running BGP but OSPF. Why would the "show ip bgp" choose it as best?
IOS is 12.4(10b) ADVANCED ENTERPRISE SERVICES
jpl861
Level 4
Level 4
What is 192.168.0.141? Do you have a network diagram?
-John
Jon Marshall
Hi Danilo
I'm not sure of your topology so i could be wrong but it looks like the route for 192.168.0.0/20 is being learnt from both EBGP and also the IGP which in your case is OSPF.
A route learned from EBGP gets a weight of 0. A route learned from the IGP gets a weight of 32768. Weight is used above all else to determine which route to insert into the routing table.
We have the same issue here where i work and we add 40000 to the EBGP learned route to ensure that is the route inserted into the routing table.
Do you have a network statement for 192.168.0.0/20 on your RT2 router.
Jon
Hi All,
Thanks for your replies.
Jon, your right its IGP/OSPF. When I execute "show ip bgp", I'm expecting only BGP (eBGP/iBGP) routes not EGP/IGP routes so I was surprise to see IGP/OSPF learned routes in the "show ip bgp" output. The output of "show ip bgp" in RT1 and RT3 is different though. I'm curious whether local traffic will loop as I noticed some funny bandwidth utilization in R3 interface connected to R2 and SW3. I'll post R1 and R3 output tomorrow.
I'm currently in the internet cafe now so I can't post a decent diagram.
# Connections
R1 crossed-cable to R2
R2 crossed-cable to R3
R1 GRE Tunnel to R3
SW1 patch cable to R1
SW2 patch cable to R2
SW3 patch cable to R3
SW1 crossed-cable to SW2
#Loopback0 IP Address and use
R1/loopback0(BGP/OSPF source)=192.168.0.254
R2/loopback0(BGP/OSPF source)=192.168.0.253
R3/loopback0(BGP/OSPF source)=192.168.0.252
SW1/loopback0(OSPF source)=192.168.1.254
SW2/loopback0(OSPF source)=192.168.1.253
SW3/loopback0(OSPF source)=192.168.1.252
#HSRP
HSRP between R1/R2 and SW1/SW2
R1=192.168.0.130/28
R2=192.168.0.131/28
R1/R2-VIP=192.168.0.129
SW1=192.168.0.141/28
SW2=192.168.0.142/28
SW1/SW2-VIP=192.168.0.140/28
#BGP
R1 BGP Statement
router bgp 65123
bgp router-id 192.168.0.254
network 192.168.0.0/20
aggregate-address 192.168.0.0 255.255.240.0 summary-only
neighbor 192.168.0.252 remote-as 65123
neighbor 192.168.0.252 description BGP with RT3
neighbor 192.168.0.252 password secret
neighbor 192.168.0.252 update-source Loopback0
neighbor 192.168.0.252 version 4
neighbor 192.168.0.252 next-hop-self
neighbor 192.168.0.252 soft-reconfiguration inbound
neighbor 192.168.0.253 remote-as 65123
neighbor 192.168.0.253 description BGP with RT2
neighbor 192.168.0.253 password secret
neighbor 192.168.0.253 update-source Loopback0
neighbor 192.168.0.253 version 4
neighbor 192.168.0.253 next-hop-self
neighbor 192.168.0.253 soft-reconfiguration inbound
-removed_external_peer_statement-
maximum-paths 2
no auto-summary
R2 BGP Statement
router bgp 65123
bgp router-id 192.168.0.253
neighbor 192.168.0.254 remote-as 65123
neighbor 192.168.0.254 description BGP with RT1
neighbor 192.168.0.254 password secret
neighbor 192.168.0.254 update-source Loopback0
neighbor 192.168.0.254 version 4
neighbor 192.168.0.254 next-hop-self
neighbor 192.168.0.254 soft-reconfiguration inbound
maximum-paths 2
no auto-summary
R3 BGP Statement
router bgp 65123
bgp router-id 192.168.0.252
maximum-paths 2
no auto-summary
#OSPF
R1/R2/R3/SW1/SW2/SW3 OSPF
router ospf 65123
router-id R1_R2_R3_SW1_SW2_SW3_loppback0_ip_address
log-adjacency-changes
redistribute connected subnets
redistribute static subnets
network 192.168.0.0 0.0.15.255 area 0
