877 No boot file - but appears to have IOS
aklobemnz
Hi All,
I have two 877's that have both reset with the following messages on boot, and dir of flash and lost+found
Any and all advice / help appreciated.  It appears that there is a IOS on the flash? but rommon doesn't know where it is.  I tried to "set" with no luck as set is read.
I have noticed that the IOS is 0 size.  Thoughts?
Much thanks.
System Bootstrap, Version 12.3(8r)YI3, RELEASE SOFTWARE
Copyright (c) 2006 by cisco Systems, Inc.
Testing lower main memory - data equals address
Testing lower main memory - checkerboard
Testing lower main memory - inverse checkerboard
Clearing lower 16K memory for cache initialization
Clearing bss
Initializing Flash
Reading monitor variables from NVRAM
Finish Reading monitor variables from NVRAM.
Enabling interrupts
Enabling instruction cache
Reading cookie
Initializing main memory
Sizing NVRAM
Exiting init
C870 series (Board ID: 1-148) platform with 131072 Kbytes of main memory
No bootable image file: flash:/
Unable to open boot file
Clearing bss
Initializing Flash
Enabling interrupts
Reading cookie
Sizing NVRAM
Exiting init
rommon 1 > dir flash:
Directory of flash:/
2    -rwx  0         <date>               c870-advipservicesk9-mz.124-6.T6.bin
16   drwx  64        <date>               lost+found
4    -rwx  1038      <date>               home.shtml
5    -rwx  2253      <date>               sdmconfig-8xx.cfg
6    -rwx  102400    <date>               home.tar
7    -rwx  1051648   <date>               common.tar
8    -rwx  4739072   <date>               sdm.tar
9    -rwx  491213    <date>               128MB.sdf
10   -rwx  780       <date>               vlan.dat
11   -rwx  65536     <date>               crashinfo_20071218-201850
12   -rwx  65536     <date>               crashinfo_20071220-065447
13   -rwx  32768     <date>               crashinfo_20071221-131956
14   -rwx  65536     <date>               crashinfo_20071222-233722
15   -rwx  284059    <date>               crashinfo_20080214-051052
19771392 bytes available (7839744 bytes used)
rommon 2 > dir flash:\lost+found
Directory of flash:lost+found/
3    -rw-  925876    <date>               00003
Leo Laohoo
Your IOS is corrupt.
The fastest way to push the IOS back into the router is via TFTPdnld.
Before you push the IOS, make sure you compare the MD5 hash value at the Cisco website.
Angus Bishop
Use a recovery method tftpdnld or xodem to put image to the flash.
Before reloading the n/w deviced we need to verify the checksum.
Please let me know if u need any help
Sent from Cisco Technical Support Android App
