880 router & ADSL
eric.baines
I want to upgrade the routers at our small offices and the 880 series routers look ideal. Just one problem - I need an ADSL interface.
Anyone know if and when Cisco are going to provide an 880 series router with an ADSL interface? Or is there some clever trickery to achieve the same end?
Cheers
Eric
rmcarthur
Hi Eric,
"ADSL2/VDSL2 support for the Cisco 880 Series will be available by the end of 2008."
The above from DSL Features in:
http://www.cisco.com/en/US/prod/collateral/routers/ps380/qa_c67_458826.html
As they're fixed configuration, there is no amount of trickery that will help I'm afraid ;)
HTH,
Ross
