881-sec-k9 config problem
20110619Day
Hi there,
1st time user of Cisco Router. 881-SEC-K9.
Can get the router to connect to the internet. Classic setup - Router behind ADSL Modem - LAN.
Configure 881 thru CiscoConfigurator, straight forward
- PPoE encapsulated
- dynamic IP address
- DNS enabled "enable DNS based hostname to address translation"
- dynamic DNS methods (default): ccp_ddns1   parameter DDNS (? correct)
When testing the connection. I get the following error msg: "configure the command "ip domain-lookup" in the config mode on the router"
No difference if "no ip domain-lookup" is selected, or "ip domain-lookup".
If I set DNS = to known IP address extern -> DNS lookup successful, but no IP address assigned dynamically.
==========================start of config file===================================
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ES_WAN$
no ip address
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
pppoe-client dial-pool-number 1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$
ip address 192.168.21.1 255.255.255.0
ip nat inside
no ip address
no ip directed-broadcast (default)
ip nat outside
ppoe enable group global
no sh
ip tcp adjust-mss 1412
interface Dialer0
ip address dhcp client-id FastEthernet4
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxxxx/000000000@xxxxxxxxx
ppp chap password 0 11111111
ppp pap sent-username xxxxxxx/00000000@xxxxxx password 0 11111111
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.7
dialer-list 1 protocol ip permit
no cdp run
==========================end of config file===================================
With an external DNS accepted, the error message changes to Interface IP address :Not assigned/received
Appreciate any feedback!
I'm lost.
Stefan
27-Sep
Hi Stefan,
in your currently used router it seems you got the DNS and Gateway from tour ISP but here you only received an address but no DNS.if this is the same ISP then of course you can use these DNS servers instead of Google one.
just put them in your DHCP pool:
ip dhcp pool ccp-pool1
   import all
   network 192.168.21.0 255.255.255.0
   default-router 192.168.21.1
   dns-server 217.237.151.115 217.237.148.102
So your Pcs will get their DNS servers from DHCP.
as you don't need DNS-cache anymore on your router and you don't need to ping by name from router then you can do this:
config# no ip name-server 8.8.8.8
config# no ip dns server
PPPoE is what you're using, username/password  what are you talking about? and DHCP is solved.
Regards.
Alain.
29 Replies 29
mavespig
Level 3
Level 3
Hi Stefan,
Can you try to change the dialer interface to use "ip address negotiated" instead of dhcp?
The IP address should be assigned in the IPCP phase of PPP, not via DHCP.
Regarding the "ip domain-lookup" command, this has effect only locally, on the router.
For example, if from the router CLI you type "ping google.com", IOS will try to resolve the name using the configured DNS server.
This will not have any effect on the end users connected via LAN.
Hope this helps
Marco
Hello agn Marco and whoever reads this,
I did as you said manually: No change in behaviour.
Still don't get connection.
The resulting cong file looks like this:
ip source-route
ip dhcp excluded-address 192.168.21.100 192.168.21.254
ip cef
ip ddns update method ccp_ddns1
DDNS both
no ipv6 cef
license udi pid CISCO881-SEC-K9 sn FCZ1514925F
username cp880admin privilege 15 secret 5 $1$ZAkn$1gqERgzCqu855sybC8E8J1
description $ES_WAN$$ETH-WAN$
no ip address
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Dialer0
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname xxxxxxxxxxxxx
ppp chap password 0 xxxxxxxxxxx
ppp pap sent-username xxxxxxxxxx
no cdp enable
router rip
no auto-summary
The resulting error message reads:
"checking for DNS settings failed"
and Cisco's help screen recommends: "configure the command 'ip-domain lookup' in teh routers config menu - but I've been there before....
So I tried something else: I enabled the DNS server IP address and added the "outside" IP address of my ISP at my location... something like 91.2.xxx.xx
Upon testing the connection now, the protocol/error msg reads as follows:
"checking for DNS settings...... successful"
"checking inteterface IP address .... successful"
"checking exit interface ...... failed"
So apparently, with the ISP's IP adress the DNS is resolved.
But this method seems to be not right, anyway.
I'm still lost. Tried anything that makes sense to me.
Anyone here to help?
Thank you and best regards,
Stefan
29-Sep
20110619Day
Hello Marco,
I tried "IP address negotiated".
Problem: Compared to using "dynamic IP" in mode "negotiated" it is NOT possible to input UserName and Password. These 2 input fields simply disappear when chosing "negotiated".
Only in "dynamic" mode it is possible to input UserName and Password.
Makes sense? I don't know.
Best regards and thank you!
Stefan
27-Sep
I don't understand your reply, sorry...
"dynamic IP" is not an available option for the dialer interface.
I suggest you connect directly to the router via console, instead of using web tools, and verify what it is happening.
PPPoE is completely independent from DNS, and the router itself does not need to know any DNS server.
Configure the dialer with ip add negotiated, then enable deb ppp nego.
Shut/no shut the dialer interface and collect the debug logs. You should be able to see there if the interface is coming up with an IP address, or not.
Once the dialer interface is up/up with an IP, you can start looking at DNS configuration.
Hi Marco,
pls excuse my igorance - I'm not familiar with the console commands.
I succeeded to connect to Router via console...
I see the "Cisco880Router#"
I input "interface Ethernet1"
no ipaddress
exit
what is "deb ppp nego"?
Pls type the command lines, so I understand.
Sorry abt this, pls hang in with me.
Thank you and rgs,
Stefan
once you get this prompt hostname# then enter config t then int f0/4
once in interface config type shut then type do debug ppp negotiation and do debug ppp authentication and then no shut .
So you'll be bringing the interface down then enable debugging for PPP and then bring the interface back up and the debug output will tell you what is happening, just paste the output here.
Regards.
Alain.
Hi Alain and/or Marco,
pls don't "shoot" commands to me. I said I am NOT familiar with the terminal commands. It's difficult for me to understand what is "text" and what is "command" in your response.
Here is what I understood and have done:
Cisco880Router#config t
Enter configuration commands, one per line.  End with CNTL/Z.
Cisco880Router(config)#int f0/4
        not work, the "/" is not accepted>
% Invalid input detected at '^' marker.
Cisco880Router(config)#inter fastethernet4
Cisco880Router(config-if)#shut
Cisco880Router(config-if)#do debug ppp negotiation
PPP protocol negotiation debugging is on
Cisco880Router(config-if)#do debug ppp authentication
PPP authentication debugging is on
Cisco880Router(config-if)#no shut
Nothing happens.
Pls use the command structure and tell me exactly what and where I have to type in commands.
Thank you very much in advance.
Best rgs,
Stefan
the command you enterd were ok. Now how are you connected to the router? via a console cable or via an ethernet cable and you telneted into the router?
do following:
config# logging console debug
config# logging monitor debug
config# exit
# terminal monitor
You  can now shut/no shut the interface and you should see debug outputs on your screen.
Paste the output and copy here.
Regards.
Alain.
Hello again,
I connect to the Router for convenience reasons by Ethernet with CCP, then join the COmmunity and do Discover, and then I switch to the Telnet  - Launch Telnet Window and continue in the Telenet window.
Here is the log:
Cisco880Router#conf t
Cisco880Router(config)#logging console debug
Cisco880Router(config)#logging monitor debug
Cisco880Router(config)#exit
Cisco880Router#terminal monitor
*Sep 30 12:40:04.475: %LINK-5-CHANGED: Interface FastEthernet4, changed state to
administratively down
*Sep 30 12:40:56.027: Vi1 PPP: Missed 5 keepalives, taking LCP down
*Sep 30 12:40:56.027: Vi1 PPP DISC: Missed too many keepalives
*Sep 30 12:40:56.027: Vi1 IPCP: Event[DOWN] State[Open to Starting]
*Sep 30 12:40:56.027: Vi1 IPCP: Event[CLOSE] State[Starting to Initial]
*Sep 30 12:40:56.027: Vi1 LCP: O TERMREQ [Open] id 2 len 4
*Sep 30 12:40:56.027: Vi1 LCP: Event[CLOSE] State[Open to Closing]
*Sep 30 12:40:56.027: Vi1 PPP: Phase is TERMINATING
*Sep 30 12:40:56.027: Vi1 LCP: Event[DOWN] State[Closing to Initial]
*Sep 30 12:40:56.027: Vi1 PPP: Phase is DOWN
*Sep 30 12:40:56.027: Di0 IPCP: Remove route to 87.186.225.25
*Sep 30 12:40:56.031: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di0
*Sep 30 12:40:56.031: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Ac
cess1, changed state to down
*Sep 30 12:40:56.035: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state t
o down
*Sep 30 12:44:45.947: %LINK-3-UPDOWN: Interface FastEthernet4, changed state to
up
*Sep 30 12:44:46.947: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et4, changed state to up
*Sep 30 12:45:00.435: %DIALER-6-BIND: Interface Vi1 bound to profile Di0
*Sep 30 12:45:00.439: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state t
o up
*Sep 30 12:45:00.439: Vi1 PPP: Sending cstate UP notification
*Sep 30 12:45:00.439: Vi1 PPP: Processing CstateUp message
*Sep 30 12:45:00.447: PPP: Alloc Context [84F3C504]
*Sep 30 12:45:00.447: ppp6 PPP: Phase is ESTABLISHING
*Sep 30 12:45:00.447: Vi1 PPP: Using dialer call direction
*Sep 30 12:45:00.447: Vi1 PPP: Treating connection as a callout
*Sep 30 12:45:00.447: Vi1 PPP: Session handle[F7000006] Session id[6]
*Sep 30 12:45:00.447: Vi1 LCP: Event[OPEN] State[Initial to Starting]
*Sep 30 12:45:00.447: Vi1 PPP: No remote authentication for call-out
*Sep 30 12:45:00.447: Vi1 LCP: O CONFREQ [Starting] id 1 len 10
*Sep 30 12:45:00.447: Vi1 LCP:    MagicNumber 0x012CA682 (0x0506012CA682)
*Sep 30 12:45:00.447: Vi1 LCP: Event[UP] State[Starting to REQsent]
*Sep 30 12:45:00.491: Vi1 LCP: I CONFREQ [REQsent] id 1 len 18
*Sep 30 12:45:00.495: Vi1 LCP:    MRU 1492 (0x010405D4)
*Sep 30 12:45:00.495: Vi1 LCP:    AuthProto PAP (0x0304C023)
*Sep 30 12:45:00.495: Vi1 LCP:    MagicNumber 0x1C4D84CC (0x05061C4D84CC)
*Sep 30 12:45:00.495: Vi1 LCP: O CONFNAK [REQsent] id 1 len 8
*Sep 30 12:45:00.495: Vi1 LCP:    MRU 1500 (0x010405DC)
*Sep 30 12:45:00.495: Vi1 LCP: Event[Receive ConfReq-] State[REQsent to REQsent]
*Sep 30 12:45:00.495: Vi1 LCP: I CONFACK [REQsent] id 1 len 10
*Sep 30 12:45:00.495: Vi1 LCP:    MagicNumber 0x012CA682 (0x0506012CA682)
*Sep 30 12:45:00.495: Vi1 LCP: Event[Receive ConfAck] State[REQsent to ACKrcvd]
*Sep 30 12:45:00.539: Vi1 LCP: I CONFREQ [ACKrcvd] id 2 len 18
*Sep 30 12:45:00.539: Vi1 LCP:    MRU 1500 (0x010405DC)
*Sep 30 12:45:00.539: Vi1 LCP:    AuthProto PAP (0x0304C023)
*Sep 30 12:45:00.539: Vi1 LCP:    MagicNumber 0x1C4D84CC (0x05061C4D84CC)
*Sep 30 12:45:00.539: Vi1 LCP: O CONFACK [ACKrcvd] id 2 len 18
*Sep 30 12:45:00.539: Vi1 LCP: Event[Receive ConfReq+] State[ACKrcvd to Open]
*Sep 30 12:45:00.575: Vi1 PPP: No authorization without authentication
*Sep 30 12:45:00.575: Vi1 PPP: Phase is AUTHENTICATING, by the peer
*Sep 30 12:45:00.575: Vi1 PAP: Using hostname from interface PAP
*Sep 30 12:45:00.575: Vi1 PAP: Using password from interface PAP
*Sep 30 12:45:00.575: Vi1 PAP: O AUTH-REQ id 1 len 55 from "t-online-com/8081009
55910@t-online-com.de"
*Sep 30 12:45:00.575: Vi1 LCP: State is Open
*Sep 30 12:45:00.631: Vi1 PAP: I AUTH-ACK id 1 len 5
*Sep 30 12:45:00.631: Vi1 PPP: Phase is FORWARDING, Attempting Forward
*Sep 30 12:45:00.631: Vi1 PPP: Queue IPCP code[1] id[1]
*Sep 30 12:45:00.631: Vi1 PPP: Phase is ESTABLISHING, Finish LCP
*Sep 30 12:45:00.631: Vi1 PPP: Phase is UP
*Sep 30 12:45:00.631: Vi1 IPCP: Protocol configured, start CP. state[Initial]
*Sep 30 12:45:00.631: Vi1 IPCP: Event[OPEN] State[Initial to Starting]
*Sep 30 12:45:00.631: Vi1 IPCP: O CONFREQ [Starting] id 1 len 10
*Sep 30 12:45:00.631: Vi1 IPCP:    Address 0.0.0.0 (0x030600000000)
*Sep 30 12:45:00.631: Vi1 IPCP: Event[UP] State[Starting to REQsent]
*Sep 30 12:45:00.635: Vi1 PPP: Process pending ncp packets
*Sep 30 12:45:00.635: Vi1 IPCP: Redirect packet to Vi1
*Sep 30 12:45:00.635: Vi1 IPCP: I CONFREQ [REQsent] id 1 len 10
*Sep 30 12:45:00.635: Vi1 IPCP:    Address 87.186.225.25 (0x030657BAE119)
*Sep 30 12:45:00.635: Vi1 IPCP: O CONFACK [REQsent] id 1 len 10
*Sep 30 12:45:00.635: Vi1 IPCP: Event[Receive ConfReq+] State[REQsent to ACKsent
*Sep 30 12:45:00.635: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Ac
cess1, changed state to up
*Sep 30 12:45:00.679: Vi1 IPCP: I CONFNAK [ACKsent] id 1 len 10
*Sep 30 12:45:00.679: Vi1 IPCP:    Address 91.4.225.129 (0x03065B04E181)
*Sep 30 12:45:00.679: Vi1 IPCP: O CONFREQ [ACKsent] id 2 len 10
*Sep 30 12:45:00.679: Vi1 IPCP: Event[Receive ConfNak/Rej] State[ACKsent to ACKs
ent]
*Sep 30 12:45:00.723: Vi1 IPCP: I CONFACK [ACKsent] id 2 len 10
*Sep 30 12:45:00.723: Vi1 IPCP:    Address 91.4.225.129 (0x03065B04E181)
*Sep 30 12:45:00.723: Vi1 IPCP: Event[Receive ConfAck] State[ACKsent to Open]
*Sep 30 12:45:00.731: Vi1 IPCP: State is Open
*Sep 30 12:45:00.731: Di0 IPCP: Install negotiated IP interface address 91.4.225
.129
*Sep 30 12:45:00.731: Di0 IPCP: Install route to 87.186.225.25
I hope this helps you to understand what's going on.
Best regards,
Stefan
30-Sep-2011
So you received an IP address from your provider via PPP.
Now can you do : # show ip route and # show run | inc name
Post output.
Regards.
Alain.
Here we go:
Cisco880Router#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, + - replicated route
Gateway of last resort is not set
      87.0.0.0/32 is subnetted, 1 subnets
C        87.186.225.25 is directly connected, Dialer0
      91.0.0.0/32 is subnetted, 1 subnets
C        91.4.220.23 is directly connected, Dialer0
      192.168.21.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.21.0/24 is directly connected, Vlan1
L        192.168.21.1/32 is directly connected, Vlan1
Cisco880Router#show ip run | inc name
Cisco880Router#show run | inc name
hostname Cisco880Router
subject-name cn=IOS-Self-Signed-Certificate-164076407
ppp chap hostname t-online-com/808100955910@t-online-com.de
ppp pap sent-username t-online-com/808100955910@t-online-com.de password 0 1234567
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
It is strongly suggested that you create a new username with a privilege level
username privilege 15 secret 0
Replace and with the username and password you
Cisco880Router#
Cisco880Router#
What do read from this?
Best regards,
Stefan
Can you ping 87.186.225.25 from the router?
You've got no dns from the provider and it seems the above address is your gateway.
try to ping 8.8.8.8 and if it fails then do this: config# ip route 0.0.0.0 0.0.0.0 dialer0 then try again.
To ping: # ping 87.186.225.25
Regards.
Alain.
Hi Alain,
I have no diea what I'm doing here.
See the trace:
Cisco880Router#ping 87.186.225.25
Sending 5, 100-byte ICMP Echos to 87.186.225.25, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Cisco880Router#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Configuring from terminal, memory, or network [terminal]? t
Cisco880Router(config)#ip route 0.0.0.0 0.0.0.0 dialer0
U.U.U
Success rate is 100 percent (5/5), round-trip min/avg/max = 52/54/56 ms
U.U.U
Success rate is 100 percent (5/5), round-trip min/avg/max = 52/53/56 ms
Cisco880Router#
So it works only with 8.8.8.8. (what is this?) and only after I implement the additional command.
Best regards,
Stefan
I get it now!
I can ping Google's public DNS server @ 8.8.8.8 but not my providers IP.
That's strange - eh???
Good luck!
Best regards from sunny Bavaria,
Stefan
