881G+7-K9 3G modem issue
startx001
Hi all ,
I can make 3g modem to work , to get ip , or to ping 8.8.8.8
Also on interface cellular 0 i can chose only slip encapsulation. What is the issue ?
here is my config:
chat-script hspa-R7 "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
chat-script 3gdata "" "ATDT*98*1#" TIMEOUT 30 CONNECT
controller Cellular 0
interface Cellular0
description WAN towards MTS
no ip address
ip mtu 1452
encapsulation slip
dialer in-band
dialer string 3gdata
dialer-group 1
async mode interactive
interface Dialer1
ip address negotiated
ip mtu 1452
ip nat outside
ip virtual-reassembly in
encapsulation slip
load-interval 30
dialer in-band
dialer idle-timeout 2147483
dialer-group 1
line 3
script dialer 3gdata
login
modem InOut
no exec
transport input all
transport output all
autoselect during-login
autoselect slip
ip route 8.8.8.8 255.255.255.255 Dialer1
dialer-list 1 protocol ip permit
access-list 1 permit any
ustanicka#sh cellular 0 network
Current Service Status = Normal, Service Error = None
Current Service = Combined
Packet Service = UMTS/WCDMA (Attached)
Packet Session Status = Inactive
Current Roaming Status = Home
Network Selection Mode = Automatic
Country = SRB, Network = MTS
Mobile Country Code (MCC) = 220
Mobile Network Code (MNC) = 3
Location Area Code (LAC) = 21101
Routing Area Code (RAC) = 1
Cell ID = 32286
Primary Scrambling Code = 140
PLMN Selection = Automatic
Registered PLMN =  , Abbreviated =
Service Provider = mt:s
ustanicka#sh cellular 0 pro
ustanicka#sh cellular 0 profile
Profile 1 = INACTIVE* **
PDP Type = IPv4
Access Point Name (APN) = gprswap
Authentication = CHAP
Username: mts
Password: 064
  * - Default profile
Configured default profile for active SIM 0 is profile 1.
Hello.
You configuration is not correct.
You need something like:
interface Cellular0/0
  no ip address
  encapsulation ppp
  load-interval 60
  dialer in-band
  dialer pool-member 1
interface Dialer1
  ! ip access-group 100 in
ip nat outside
encapsulation ppp
  dialer pool 1
dialer persist
no ip redirects
no ip unreachable
ppp chap password ...
If you are unable to use "encapsulation ppp" under c0 interface - try to update to newer IOS.
