887va ADSL/aal5snap Configuration Problem.
spamcollec
Hi All,
We have currently bought a new 887va Cisco Router.
I have a problem in configuration. Just cant get what wrong.
ISP--Cisco887va--FortyGate (like using router as modem)
Thank You.
Current configuration : 1760 bytes
version 15.2
no service pad
service password-encryption
hostname PicsixDialer
boot-start-marker
boot-end-marker
enable secret
no aaa new-model
memory-size iomem 10
clock timezone Jerusa 2 0
no ip domain lookup
ip cef
no ipv6 cef
license udi pid CISCO887VA-K9 sn FTX1738828N
controller VDSL 0
interface Ethernet0
no ip address
shutdown
interface ATM0
no ip address
ip nat outside
ip virtual-reassembly in
no atm ilmi-keepalive
pvc 8/48
  encapsulation aal5snap
  pppoe-client dial-pool-number 1
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address 172.16.11.254 255.255.255.252
ip nat inside
interface Dialer0
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap
ppp pap sent-username **** password ****
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool pool1 172.16.11.0 172.16.12.0 netmask 255.255.248.0
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 1 permit 0.0.0.0 255.255.255.0
dialer-list 1 protocol ip permit
banner motd ^CWelcome Authorized Users Unauthorized access prohibited!^C
line con 0
password 7 0835495C04100B161E
login
no modem enable
line aux 0
line vty 0 4
privilege level 15
login
transport input all
end
spamcollec
*UDP: pvc 1/32
Peter Paluch
Alexander,
Try removing the ppp authentication pap from your Dialer0 interface. This command forces your ISP to authenticate to you - which is something ISPs do not do. You should authenticate to your ISP, not the other way round.
If this does not help then please post the output of the following commands and debugs:
show ip interface brief
debug ppp negotiation
debug pppoe events
Best regards,
Peter
alexii77
Hi Alexander
you can do it w 2 ways:
1 send startup-config ftom tftp and reload
2 connect to console , remove running-config send script and save
second way :
1.Connect the RJ-45 connector at the other end of the console cable to an RJ-45 to DB9 converter.
2.Connect the DB9 connector to an open COM port on your PC.
Start and Set Up HyperTerminal
Complete these steps:
1.Start the HyperTerminal program on the PC.
2.Set up your HyperTerminal session.
1.Assign a name to your session, and click OK.
2.From the Connect To window, click Cancel.
3.From the File menu, click Properties.
4.From the Properties window, in the Connect Using list, select the COM port where you connect the DB9 end of the console cable.
5.From the Properties window click Configure and fill in these values:
?Bits per second: 9600
?Data bits: 8
?Parity: None
?Stop bits: 1
?Flow Control: None
6.Click OK.
7.From the Call menu, click Disconnect.
8.From the Call menu, click Call.
9.Press Enter until you see a router prompt on your HyperTerminal screen.
Clear Existing Configurations on the Cisco DSL Router
1. Type enable at the router prompt to enter privileged mode.
•Router>enable
•Router#
2. Clear existing configurations on the router.
•Router#write erase
•Router#reload
3. Reload the router so it boots with a blank startup configuration.
System configuration has been modified. Save? [yes/no]:no
Proceed with reload? [confirm]yes
After the router has reloaded, enter enable mode , start configure and send script :
en
conf t
no service pad
boot-start-marker
boot-end-marker
no aaa new-model
no ip routing
no ip cef
ip dhcp excluded-address 172.16.11.254
ip dhcp pool Local_DHCP_Pool
import all
network 172.16.11.0 255.255.255.0
default-router 172.16.11.254
lease 0 0 30
no ipv6 cef
controller VDSL 0
interface ATM0
no ip address
no ip route-cache
shutdown
interface Ethernet0
description -WAN$
no ip address
pppoe enable group global
bridge-group 1
no shutdown
switchport access vlan 20
no ip address
no ip address
interface FastEthernet2netw
no ip address
no ip address
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
no ip address
interface wlan-ap0
description Service module interface to manage the embedded AP
ip address 192.168.168.2 255.255.255.0
no ip route-cache
shutdown
interface Vlan1
no ip address
no ip route-cache
interface Vlan20
ip address 172.16.11.254 255.255.255.0
no ip route-cache
ip tcp adjust-mss 1412
bridge-group 1
no ip http server
bridge 1 protocol ieee
line con 0
login
no modem enable
line aux 0
line vty 0 4
privilege level 15
login
transport input all
scheduler allocate 20000 1000
end
wr
this configuration will switch your ROUTER to ADSL MODEM
