887va ADSL Configuration
ollycb1981
Hi All,
Bare with me here I am very new to Cisco routers.
We have currently bought a new 887va Cisco Router to replace our Zyxel router.
Our hosting provider sent me a configuration file to use for the router (see below), but I can't seem to just get an ip address to work on the router. Literally tried everything. If anybody could help would be great.I was hoping to set up an ip address then hoprfully use a web based graphical interface to set it up.
This is what my hosting provider sent me:
Current configuration : 1488 bytes
version 12.4                                                            ***version
information
hostname ADSLrouter                                                  *** sets
hostname of the router
boot-start-marker
boot-end-marker
enable password ****           *** sets
password to get into enable mode on router
no aaa new-model
ip cef
archive
log config
hidekeys
interface ATM0                                                            *** interface
ATM0 information/configuration
no ip address                                                            *** specifies
ADSL connection specific details
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface BRI0                                                            *** interface
BRI0 information/configuration
no ip address
encapsulation hdlc
shutdown
interface FastEthernet0                                                  *** interface
FastThernet0 information/configuration
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface Vlan1
no ip address
interface Dialer0                                                  *** interface
Dialer0 interface information/configuration
description Dialer for ADSL                                        *** includes all
of ppp authentication details etc
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no keepalive
no cdp enable
ppp authentication chap callin
ppp chap hostname ******
ppp chap password 0 *******
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0                              *** Default
static route for Dialer0 interface
no ip http server
ip nat inside source list 1 interface Dialer0 overload          *** assigns nat
to the Dialer0 interdace
access-list 1 permit 192.168.0.0 0.0.0.255                    *** Specifies
access list
control-plane
line con 0                                                            *** Specifies
details to allow access via Telnet, console etc
logging synchronous
line aux 0
line vty 0 4
password
login
end
This is my curent configuration
Current configuration : 3031 bytes
! Last configuration change at 09:13:49 UTC Mon Jul 29 2013
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$v7b.$8.3HT4oD8hoRIMs34gSDU1
enable password enablepass
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-1390929568
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1390929568
revocation-check none
rsakeypair TP-self-signed-1390929568
crypto pki certificate chain TP-self-signed-1390929568
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31333930 39323935 3638301E 170D3133 30363130 31313232
  32325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 33393039
  32393536 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100DF4C 2F0F7826 4FB77B33 6E0EDEC7 ED8A9E8B E39257ED E54822A4 4E384B5C
  A541A6A1 AAC2F798 09E741C4 D86EFA9F 8FA04B58 51B2EF67 D87F3A4F DE183869
  721AB47D 0E44EDE9 399E0216 E51107ED 9416B110 95A2304B 6159BE5E 2BD83A80
  3C6DF82F A61137B6 4FA02EAD 32E73DDA A0A89C0E F474B5C3 F0F909D8 BEBA87F1
  50A70203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14036292 33761A9B DD08B78E 98EDE20B CA42038E 99301D06
  03551D0E 04160414 03629233 761A9BDD 08B78E98 EDE20BCA 42038E99 300D0609
  2A864886 F70D0101 05050003 8181005C 85F74002 CEC49B3D AD93C129 D7CA3AB3
  9E740890 77FCF2AB A5F55EDC A223D837 1FA7EE93 82AE9022 B0664457 B887C540
  A932616D 628F87E2 BFCE7D2B 6D45023A 0AB08806 07F3351D 5178300C 19B54782
  828EDAA2 856D7275 3BDF5D36 DCFE6563 2642FF09 3826E013 38C3EF20 9B6D8FBE
  10C13B9E FABE0BBC FFD0C518 D7DA8E
        quit
ip source-route
no ip routing
no ip cef
no ipv6 cef
license udi pid CISCO887VA-M-K9 sn FCZ1712C77K
username admin privilege 15 password 0 13
controller VDSL 0
interface Ethernet0
no ip address
no ip route-cache
shutdown
interface ATM0
no ip address
no ip route-cache
shutdown
description internal interface
no ip address
no ip address
shutdown
no ip address
shutdown
no ip address
pppoe-client dial-pool-number 1
interface Vlan1
no ip address
no ip route-cache
shutdown
ip default-gateway 192.168.1.254
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
line con 0
no modem enable
line aux 0
login local
line vty 0 4
privilege level 15
password termpass
login local
transport input telnet ssh
end
On my current config I'm mainly trying to set it up so I can access the router through internet explorer so I can set It up that way.
Many thanks in advance.
3 Accepted Solutions
Michael Muenz
Level 5
Level 5
Forget the setup via http!
Go to the console,
"conf t" and paste:
interface ATM0
no ip address
no shut
pvc 0/38
interface Dialer0
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no keepalive
no cdp enable
no pppoe-client dial-pool-number 1
int vlan1
ip address 192.168.0.1 255.255.255.0 (or whatever your internal should be
ip nat inside
ip tcp adjust-mss 1300
Then go out of config-mode, plug the cable to the modem and wait a bit. Then type:
sh controller vdsl 0
and check if it's in sync. If yes, type "sh int di0" and look at line 2 or 3 if you got an IP.
Michael
Please rate all helpful posts
Michael Please rate all helpful posts
conf t
int vlan1
no shut
int di0
ppp ipcp dns request
ppp ipcp route default
access-list 150 permit ip 192.168.100.0 0.0.0.255 any
ip nat inside source list 150 interface Dialer0 overload
Then you shoul be fine if you plug your network (LAN) in Port FA0
Michael
conf t
ip cef
ip routing
Your Switch is connected to port FA0?
Michael
9 Replies 9
Michael Muenz
Level 5
Level 5
Go to the console,
"conf t" and paste:
interface ATM0
no ip address
no shut
pvc 0/38
interface Dialer0
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no keepalive
no cdp enable
int vlan1
ip nat inside
Michael
Hi Michael,
Thanks for that, this is what it came up with after:
Dialer0 is up, line protocol is up (spoofing)
  Hardware is Unknown
  Internet address is 213.2.98.233/32
  MTU 1500 bytes, BW 56 Kbit/sec, DLY 20000 usec,
  Encapsulation PPP, LCP Closed, loopback not set
  Keepalive not set
  DTR is pulsed for 1 seconds on reset
  Interface is bound to Vi2
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 00:25:27
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 42 kilobits/sec
     7 packets input, 746 bytes
     20 packets output, 1200 bytes
Bound to:
Virtual-Access2 is up, line protocol is up
  Hardware is Virtual Access interface
  MTU 1500 bytes, BW 960 Kbit/sec, DLY 20000 usec,
  Encapsulation PPP, LCP Open
  Open: IPCP
  PPPoATM vaccess, cloned from Dialer0
  Vaccess status 0x44
  Bound to ATM0 VCD: 1, VPI: 0, VCI: 38, loopback not set
  Keepalive not set
  DTR is pulsed for 5 seconds on reset
  Interface is bound to Di0 (Encapsulation PPP)
  Last input 00:00:06, output never, output hang never
  Last clearing of "show interface" counters 00:21:19
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     48 packets input, 3206 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     40 packets output, 1636 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
I tried connecting through the internet and I still couldn't! is there something else I need to change in my config:
Current configuration : 3424 bytes
! Last configuration change at 11:20:36 UTC Mon Jul 29 2013
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
        quit
ip source-route
no ip routing
no ip cef
no ipv6 cef
username admin privilege 15 password 0 ********
controller VDSL 0
interface Ethernet0
no ip address
no ip route-cache
shutdown
interface ATM0
no ip address
no ip route-cache
pvc 0/38
no ip address
no ip address
shutdown
no ip address
shutdown
no ip address
interface Vlan1
ip address 192.168.100.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
no ip route-cache
shutdown
interface Dialer0
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no keepalive
ppp chap hostname **************
ppp chap password 0 ************
no cdp enable
ip http server
line con 0
no modem enable
line aux 0
login local
line vty 0 4
privilege level 15
password termpass
login local
end
Many thanks for your help.
conf t
int vlan1
no shut
int di0
Michael
Hi Michael,
Don't know if I'm doing something really wrong but it's still not connecting to the internet! Am I missing something, are set up is: ISP(Claranet/U-Net) ------- 887va-Router--------SG100-24-Switch------------10+Computers (Not sure if that will help)
Here's the current config:
Building configuration...
Current configuration : 3595 bytes
! Last configuration change at 12:54:53 UTC Mon Jul 29 2013 by admin
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
        quit
ip source-route
no ip routing
no ip cef
no ipv6 cef
username admin privilege 15 password 0 *************
controller VDSL 0
interface Ethernet0
no ip address
no ip route-cache
shutdown
no fair-queue
interface ATM0
no ip address
no ip route-cache
pvc 0/38
no ip address
no ip address
shutdown
no ip address
shutdown
no ip address
interface Vlan1
ip nat inside
no ip route-cache
interface Dialer0
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no keepalive
no cdp enable
ip http server
line con 0
no modem enable
line aux 0
login local
line vty 0 4
privilege level 15
password termpass
login local
end
Many Thanks
conf t
ip cef
ip routing
Michael
Brilliant, Thanks so much Michael,
One other thing I've got an ftp server aswell ip 192.168.100.104
How do I set-up port forwarding to that server on the router?
Thankyou so much for your help.
ip nat inside source static tcp 192.168.100.104 21 interface dialer 0 21
Michael
Thanks Michael,
Can I use the same command for opening http port aswell for the same server?
Sure!
Michael
