887VA Bridge Mode - VDSL2 - BT Infinity Connection
RichardRichard
Good afternoon,
I have a Cisco 887VA which I'm trying to configure as a modem only. I've been following a few threads on here regarding the VDSL config for bridged mode which seems to be what I'm after.
The modem side of the router seems to be working correctly as when I type "sh controller vdsl 0" I get the following output, which I've cropped down a little:
Modem Status:            TC Sync (Showtime!)
DSL Config Mode:         VDSL2
Trained Mode:            G.993.2 (VDSL2) Profile 17a
TC Mode:                 PTM
Selftest Result:         0x00
DELT configuration:      disabled
DELT state:              not running
Trellis:                 ON                       ON
Line Attenuation:         0.0 dB                  0.0 dB
Signal Attenuation:       0.0 dB                  0.0 dB
Noise Margin:             4.5 dB                  6.0 dB
Attainable Rate:        30632 kbits/s            6304 kbits/s
Actual Power:            11.0 dBm                 6.3 dBm
Per Band Status:        D1      D2      D3      U0      U1      U2      U3
Line Attenuation(dB):   21.4    60.4    0.1     9.2     49.8    N/A     N/A
Signal Attenuation(dB): 21.4    60.4    N/A     9.2     49.2    N/A     N/A
Noise Margin(dB):       4.4     4.6     N/A     6.0     6.0     N/A     N/A
However, the router (Draytek 3900) which I have connected to the 887VA is failing it's PPoE connection with an error "Message [ PPPoE : No response from server side. ]". I have also tried using a Windows PPoE connection and it fails with "Error 651".
I'm suspicious that my interface config on the Ethernet is incorrect, I'm new with Cisco devices so it's entirely possible I've done something stupid. The BT infinity instructions for VDSL are just to use a VLAN tag of 101 at the modem so I've attempted to modify other bridged configs on this forum to do exactly that.
Here is my current router config:
Current configuration : 1280 bytes
! Last configuration change at 07:46:08 UTC Fri May 4 2018
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip source-route
ip cef
no ipv6 cef
license udi pid CISCO887VA-SEC-K9 sn FCZ1538C573
controller VDSL 0
 operating mode vdsl2
interface Ethernet0
 no ip address
 no ip route-cache cef
 no ip route-cache
 shutdown
interface Ethernet0.101
 encapsulation dot1Q 101
 no ip route-cache
 bridge-group 1
interface ATM0
 no ip address
 no ip route-cache
 shutdown
 no atm ilmi-keepalive
interface FastEthernet0
switchport access vlan 101
no ip address
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
no ip address
no ip route-cache
interface Vlan101
ip address 172.16.11.254 255.255.255.0
no ip route-cache
ip tcp adjust-mss 1412
bridge-group 1
ip forward-protocol nd
no ip http server
no ip http secure-server
logging esm config
control-plane
bridge 1 protocol ieee
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
 transport input all
end
I have tried using both Ethernet port 0 and port 1 to connect to the WAN port on my Dratytek and also with my PPoE connection on the PC but both behave the same and fail to connect.
Thanks for reading, hopefully someone can spot the error of my ways!
RichardRichard
Just an update. Fixed the issue by changing the Ethernet0 config.
Will post the full working config when I get chance!
Hi Richard,
I have the same problem!
Can you post your working config? Maybe that would help me :-)
Cheers!
Robert.
I hope this was not the problem in the original post:
interface Ethernet0
no ip address
no ip route-cache
--> shutdown
Either way, post the config you currently have...
Apologies, I completely forgot!
This is was the config that got me up and running;
Router#sh running-config
Building configuration...
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ipv6 cef
controller VDSL 0
interface Ethernet0
no ip address
no ip route-cache
shutdown
no ip route-cache
bridge-group 1
interface ATM0
no ip address
no ip route-cache
shutdown
interface Vlan1
no ip address
ip virtual-reassembly in
no ip route-cache
bridge-group 1
no ip http server
logging esm config
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
end
