887VA-K9 Bandwidth shaping policy Issue
mrdavies2066
Hi All,
I have been trying to add a basic bandwidth shaping policy to my Cisco 887-K9 and seem to be having a few issues, I am running firmware version 15.7(3)M7.
In my config i have four vlans with one assigned to each of the four fast ethernet adapters:
vlan 100 - WAN - DHCP
vlan 110 - SecureLAN - IP-192.168.1.1
vlan 120 - GuestLAN - IP-192.168.1.2
vlan 130 - IoTLAN - IP-192.168.1.3
Each LAN side vlan has a DHCP scope configured
All three LAN vlans NAT via the WAN (vlan100)
I am trying to apply traffic shaping to fe1 or vlan110 (i have tried both)
class-map match-any ClassSecure
match any
policy-map SecureTrafficShape
class ClassSecure
shape average percent 1  (have also tried "shape average 1000") - these are both test values
When trying to add the above config to an interface vlan or fe i receive the following error:
Router(config)#interface vlan 110
Router(config-if)#service-policy output SecureTrafficShape
Configuration failed!
When this happens I can see not event logged explaining why, despite having added the following logging options:
logging history debugging
logging buffer debugging
I have found that if i remove the shape command I am then able to apply the policy map to an interface I can the re-add the shape command after:
no shape average percent 1
Running "show policy-map interface" seems to confirm the class map is picking up the traffic but no matter what I try to limit the traffic to, either 1% or 1000bits/s iPerf shows no reduction in throughput on the interface.
Vlan110
Service-policy output: SecureTrafficShape
Class-map: ClassSecure (match-any)
41052 packets, 4864553 bytes
5 minute offered rate 118000 bps, drop rate 0000 bps
Match: any
Queueing
queue limit 64 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 173/30161
shape (average) cir 1000000, bc 10000, be 10000
target shape rate 1000000
Class-map: class-default (match-any)
0 packets, 0 bytes
5 minute offered rate 0000 bps, drop rate 0000 bps
Match: any
(pkts output/bytes output) 0/0
iPerf Results:
Accepted connection from 192.168.0.24, port 51022
[ 5] local 192.168.0.205 port 5201 connected to 192.168.0.24 port 51023
[ ID] Interval Transfer Bandwidth
[ 5] 0.00-1.00 sec 10.6 MBytes 88.7 Mbits/sec
[ 5] 1.00-2.00 sec 10.6 MBytes 89.2 Mbits/sec
[ 5] 2.00-3.00 sec 10.9 MBytes 91.4 Mbits/sec
[ 5] 3.00-4.00 sec 10.9 MBytes 91.5 Mbits/sec
[ 5] 4.00-5.00 sec 10.9 MBytes 91.6 Mbits/sec
[ 5] 5.00-6.00 sec 11.0 MBytes 92.5 Mbits/sec
[ 5] 6.00-7.00 sec 11.0 MBytes 92.0 Mbits/sec
[ 5] 7.00-8.00 sec 10.9 MBytes 91.8 Mbits/sec
[ 5] 8.00-9.00 sec 11.0 MBytes 92.6 Mbits/sec
[ 5] 9.00-10.00 sec 11.0 MBytes 92.6 Mbits/sec
[ 5] 10.00-10.04 sec 493 KBytes 93.5 Mbits/sec
[ 5] 0.00-10.04 sec 0.00 Bytes 0.00 bits/sec sender
[ 5] 0.00-10.04 sec 109 MBytes 91.4 Mbits/sec receiver
Am i missing something here? Any advice gratefully received.
See below for full config details
Router#show run
Building configuration...
Current configuration : 3028 bytes
! Last configuration change at 23:07:19 UTC Mon Nov 30 2020
version 15.7
no service pad
hostname Router
boot-start-marker
boot-end-marker
no logging console
aaa new-model
aaa session-id common
memory-size iomem 10
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp excluded-address 192.168.2.1 192.168.2.10
ip dhcp excluded-address 192.168.3.1 192.168.3.10
ip dhcp pool name DHCP
network 192.168.1.0 255.255.255.0
domain-name ******.local
dns-server 192.168.1.1
netbios-name-server 192.168.1.1
default-router 192.168.1.1
ip dhcp pool DHCP
import all
ip dhcp pool name DHCP-Guest
import all
network 192.168.2.0 255.255.255.0
dns-server 192.168.2.1
netbios-name-server 192.168.2.1
default-router 192.168.2.1
ip dhcp pool name DHCP-IoT
import all
network 192.168.3.0 255.255.255.0
dns-server 192.168.3.1
netbios-name-server 192.168.3.1
default-router 192.168.3.1
ip domain name ******.local
ip host ap.******.local 192.168.1.10
ip host printer.******.local 192.168.1.5
ip hostname strict
ip name-server 208.67.222.222
ip name-server 208.67.220.220
ip cef
no ipv6 cef
license udi pid CISCO887VA-K9 sn F000000000
controller VDSL 0
shutdown
match any
class ClassSecure
interface Ethernet0
no ip address
shutdown
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
switchport access vlan 100
switchport mode access
no ip address
interface FastEthernet1
switchport access vlan 110
no ip address
spanning-tree portfast
interface FastEthernet2
switchport access vlan 120
no ip address
interface FastEthernet3
switchport access vlan 130
no ip address
interface Vlan1
no ip address
interface Vlan100
description WAN
ip address dhcp
ip nat outside
ip virtual-reassembly in
interface Vlan110
description Secure
ip nat inside
interface Vlan120
description Guest
ip address 192.168.2.1 255.255.255.0
ip nat inside
interface Vlan130
description IoT
ip address 192.168.3.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list NATACL interface Vlan100 overload
ip access-list standard NATACL
permit 192.168.1.0 0.0.0.255
permit 192.168.2.0 0.0.0.255
permit 192.168.3.0 0.0.0.255
what are you trying to accomplish ? Do you want to limit the amount of traffic users in Vlan 10 can use outbound ? Try the below (traffic for Vlan 110 is shaped to 10Mbit in this example):
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
class-map match-all VLAN110_CM
match ip address 101
policy-map VLAN110_PM
class VLAN110_CM
shape average 10000000
class-class default
fair-queue
interface Vlan100
service-policy output VLAN110_PM
7 Replies 7
class VLAN110_CM
class-class default
fair-queue
interface Vlan100
Hi Georg,
Thanks for your reply.
What I am hoping to do is ensure that no one endpoint can consume all available bandwidth of my internet connection. I have tried to enter your example which gave the following result:
Router(config)#access-list 101 permit ip 192.168.1.0 0.0.0.255 any
Router(config)#class-map match-all VLAN110_CM
Router(config-cmap)#match ip address 101
% Invalid input detected at '^' marker.
Router(config-cmap)#policy-map VLAN110_PM
Router(config-pmap)#
Router(config-pmap)#class VLAN110_CM
Router(config-pmap-c)#
Router(config-pmap-c)#shape average 10000000
Router(config-pmap)#class-class default
Router(config-pmap-c)#fair-queue
exit
Router(config)#interface Vlan100
Router(config-if)#service-policy output VLAN110_PM
From what I can gather the most similar (i think) commands to those which were not accepted were as follows:
exit
match access-group 101
exit
class VLAN110_CM
exit
class class-default
fair-queue
exit
interface Vlan100
This resulted in the following config (not sure if this is quite the same):
class VLAN110_CM
class class-default
fair-queue
interface Vlan100
description WAN
ip address dhcp
ip nat outside
So still getting "Configuration failed!" failed when trying to apply to the vlan interface, not sure why. Also seems odd/unhelpful that nothing is logged.
Many thanks
Mark
apply the service policy outbound to the physical interface that is the uplink to the ISP (which one is that, actually, as I cannot see that in your config)?
The physical interface I am using to connect to my ISP is fast ethernet 0 (vlan 100). This currently has a class c subnet applied but will be connected directly to a modem and receive an IP via DHCP from my ISP once the config is finished.
Attempting this seems to yield the same result:
Router(config)#interface fastEthernet 0
Mark
I think on this platform, you can only apply a service policy to a physical layer 3 interface. FastEthernet0 is layer 2 only, so that won't work anyway.
Well that i a shame but good to have a reason as to why it won't play ball, i imagined there would be one.
Do you have any other ideas of how I may achieve my aim via another method?
Thanks very much for your input on this.
Mark
I notice I am able to apply this policy-map to ethernet 0 (internal virtual interface).
I know this is a long shot but i don't suppose there is anyway to bridge/link fe0 to ethernet0 in a way which may allow this to work?
Mark
