12-02-2020 03:20 AM
Hello
I have ASR 903 and i want to copy "asr900rsp2-universalk9_npe.16.09.04.SPA.bin" from USB to bootflash : RSP1 ( backup ) But i have a error :
Router#copy usb0: flash:
Error: Licensing infrastructure is NOT initialized.
Source filename [asr900rsp2-universalk9_npe.16.09.04.SPA.bin]?
Destination filename [asr900rsp2-universalk9_npe.16.09.04.SPA.bin]?
%Error opening bootflash:/asr900rsp2-universalk9_npe.16.09.04.SPA.bin (Permission denied)
what is the problem for RSP 1 ( stanby ) and what is the solution
i wait from ecpert ASR 900 help me and i wait a reply
thanks
12-02-2020 03:31 AM
The problem RSP 1 for ASR 903 ( stanby )
Router#dir flash:
Directory of bootflash:/
22 drwx 4096 May 23 2019 01:48:29 +00:00 lost+found
75523 drwx 4096 May 23 2019 01:50:24 +00:00 .installer
135939 drwx 4096 Dec 2 2020 10:05:33 +00:00 core
75525 drwx 4096 Dec 2 2020 10:05:19 +00:00 .prst_sync
60418 drwx 4096 Dec 2 2020 10:07:11 +00:00 tracelogs
30212 drwx 4096 Dec 2 2020 10:05:34 +00:00 .rollback_timer
15108 drwx 4096 Dec 2 2020 10:06:57 +00:00 .dbpersist
Router#copy usb0: bootflash:
so what is solution of RSP1 ?,
12-02-2020 03:39 AM
Not sure what exactly you trying to do here ? are you in the process of upgrade ?
RSP1 is standby ? is this correct ?
i also see some messages here ?
clear platform license-partition and reload the module. ( if this is live environment do in the maintenance window ?)
12-02-2020 03:52 AM
YES , it is RSP 1 for ASR 903
1 step : rommon> copy usb0: asr900rsp2-universalk9_npe.16.09.04.SPA.bin
2 step : boot usb0 :
3step :
so that are steps in RSP 1 ( stanby ).
Just want to knwo what is the command that allow me ?? : clear platform license-partition and reload the module. ( that you tell me ) ??? !!!!! to resolve this error
thanks in advance
12-02-2020 04:06 AM
what is the command that resolve this error !!!
thanks in advance
12-02-2020 05:25 AM - edited 12-02-2020 06:16 AM
the command does not exit : clear platform license-partition !!!! this command does not exsit in ASR 903 cisco
#clear platform
condition Clear conditional debug and packet-trace configuration and data
hardware Clear platform hardware information
l2lisp platform l2lisp
software
how i can rsolve this problem and what is the command exct for ASR 903 !!??
i wait a reply from expert ASR 900 ??
thansk
12-02-2020 06:24 AM
please i need a help and i wait a answer !!
thanks
12-02-2020 02:56 PM
If this is an RSP1 then why are you copying the firmware for an RSP2?
Under the Restrictions for Upgrading from Cisco IOS XE Release 3.x to Cisco IOS XE Release 16.x, it specifically states:
RSP1 Module is not supported in Cisco IOS XE Releases 16.x.
12-02-2020 09:28 PM
Yes it was rsp standby with rsp active but now it is not rsp standby because .we plug this rsp standby from asr 903 because it have a problem and we try installed only in asr 903 ..so it became active ....!!
So we try copy ios from USB 0 to bootflash for this rsp as same work rsp0 active . It show message error as mentioned before !!!
So what's command resolve message error .
So i wait the help from you and reply ..
12-03-2020 04:46 AM
the problem is not resolved !!!
