Showing results forĀ
Search instead forĀ
Did you mean:Ā
887va-w Qos for Swisscom bluewin TV
I'm trying to configure QoS for my 887va-w for my streaming tv box by my ISP (Swisscom/Bluewin).
For that I use QoS for the UDP port 10000 because it's the port used by the box for the TV streams.
I checked with wireshark what is the difference between the capture with their router and with my cisco and the only difference is:
With ISP router:
802.1Q Virtual LAN: PRI:2, CFI:0, ID=1
With cisco router:
802.1Q Virtual LAN:Pri:0, CFI:0, ID=3
Can you help me to figured it out ?
Thanks.
Here is my config:
class-map match-any CLASS-VIDEO
match ip dscp af41
match access-group name bluewin
class-map match-any CLASS-NETWORK
match ip dscp cs7
match ip dscp cs5
class-map match-any CLASS-EXPEDITE
match ip dscp ef
match ip dscp cs3
match ip dscp af31
policy-map QOS-ETH0-OUT
class CLASS-NETWORK
bandwidth percent 5
class CLASS-EXPEDITE
priority percent 10
class CLASS-VIDEO
bandwidth percent 40
set dscp af41
class class-default
fair-queue
set dscp default
zone security INSIDE
zone security OUTSIDE
zone security BLUEWIN
zone security GUESTWLAN
zone-pair security BLUEWIN->OUTSIDE source BLUEWIN destination OUTSIDE
service-policy type inspect inside_to_outside
zone-pair security GUESTWLAN->OUTSIDE source GUESTWLAN destination OUTSIDE
service-policy type inspect Guest_to_Outside
zone-pair security INSIDE->OUTSIDE source INSIDE destination OUTSIDE
zone-pair security OUTSIDE->INSIDE source OUTSIDE destination INSIDE
service-policy type inspect OUTSIDE_INSIDE
zone-pair security INSIDE->BLUEWIN source INSIDE destination BLUEWIN
zone-pair security BLUEWIN->INSIDE source BLUEWIN destination INSIDE
interface Ethernet0
bandwidth 11012
ip nat outside
no ip mfib cef output
no ip virtual-reassembly in
ip virtual-reassembly out
zone-member security OUTSIDE
ip igmp helper-address 1.1.1.1
ip igmp query-max-response-time 8
ip igmp query-interval 30
ip igmp querier-timeout 60
ip igmp proxy-service
load-interval 30
auto discovery qos
service-policy output QOS-ETH0-OUT
interface FastEthernet1
switchport access vlan 3
no ip address
spanning-tree portfast
interface Vlan3
description Vlan for Swisscom TV
bandwidth 48453
ip address 192.168.10.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-mode
ip nat inside
zone-member security BLUEWIN
ip tcp adjust-mss 1452
ip igmp explicit-tracking
load-interval 30
auto discovery qos
ip access-list extended bluewin
permit udp any any eq 10000
0 Replies 0
