887VAG+ can not work please help ?
NTT-Router#sh run
Building configuration...
Current configuration : 2749 bytes
! Last configuration change at 05:27:05 UTC Sat Mar 3 2012 by admin
! NVRAM config last updated at 05:25:17 UTC Sat Mar 3 2012 by admin
version 15.2
no service pad
hostname NTT-Router
boot-start-marker
boot system flash:/c880data-universalk9-mz.152-2.T.bin
boot-end-marker
no aaa new-model
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.1.2
ip dhcp excluded-address 192.168.1.3
ip dhcp excluded-address 192.168.1.4
ip dhcp excluded-address 192.168.1.5
ip dhcp excluded-address 192.168.1.6
ip dhcp excluded-address 192.168.1.7
ip dhcp excluded-address 192.168.1.8
ip dhcp excluded-address 192.168.1.9
ip dhcp excluded-address 192.168.1.10
ip dhcp excluded-address 192.168.1.101
ip dhcp excluded-address 192.168.1.111
ip dhcp excluded-address 192.168.1.113
ip dhcp excluded-address 192.168.1.254
ip dhcp excluded-address 192.168.1.250
ip dhcp pool NTT-Clients
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 203.144.207.29 203.144.207.49
ip cef
no ipv6 cef
chat-script gsm "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
chat-script true "" "*99#" TIMEOUT 30 "CONNECT"
license udi pid C887VAG+7-K9 sn FGL160323E3
username admin privilege 15 secret 5 $1$na3c$gogOxmWaWXVq4q4UJsZA4.
controller VDSL 0
controller Cellular 0
gsm sim max-retry 2
interface Ethernet0
no ip address
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Cellular0
no ip address
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer idle-timeout 0
dialer string "*99#"
dialer-group 1
async mode interactive
interface Vlan1
ip nat inside
ip tcp adjust-mss 1412
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
access-list 1 permit any
access-list 101 permit ip any any
dialer-list 1 protocol ip permit
control-plane
alias exec ship show ip int brief
alias exec apn show cel 0 profile
alias exec 3g show cel 0 radio
line con 0
line aux 0
line 3
script dialer true
modem InOut
no exec
line vty 0 4
login local
transport input all
end
NTT-Router#
NTT-Router#apn
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = internet
Authentication = CHAP
Username: true, Password: true
Profile 3 = INACTIVE
PDP Type = IPv4
Access Point Name (APN) = hinternet
Authentication = None
Username: , Password:
* - Default profile
Configured default profile for active SIM 0 is profile 1.
NTT-Router#
APN always don't active
and don't show msg when use debug chat
please help
mavespig
Level 3
Level 3
Hi Siriphan,
there are a couple of things that needs to be corrected in config. Cellular interface needs to use ppp instead of slip, plus you should reference the same script in both cell interface and line.
Try this config:
chat-script gsm "" "ATDT*99#" TIMEOUT 60 "CONNECT"
interface Cellular0/1/0
ip address negotiated
encapsulation ppp
dialer in-band
dialer string gsm
dialer-group 1
ppp chap hostname
ppp chap password 0
ppp ipcp dns request
line 0/1/0
exec-timeout 0 0
script dialer gsm
login
modem InOut
no exec
If it still does not work, post the output of 'show cellular 0 all', then enable the following debugs:
- deb dialer
- deb chat
- deb ppp nego
Hope this helps
Marco
