router and switch throughput info
john field
I am trying to find a reference doc on router/swwitch throughput. I have searched on the Cisco website but had not luck so far , can anyone help?
5 Replies 5
Latchum Naidu
Hi John,
There are many modesl in Cisco routers and switches.
It is difficult to tell the throughput of any router without knowning its model.
The answer for your question is like say Cisco 1841 WAN throughput is 38.40Mbps.
Tell us which model you have so that we can find the max throughput of that.
Please rate the helpfull posts.
Naidu.
Hi Naidu,
Thanks , but I was looking for a generic reference doc from Cisco.
i.e. one that gives throughput info for a range of chassis types, from an 800 up to asr1000.
I need it as it helps to reference something like this when putting designs togther for customers
John
Hi Sean,
I  had a similar query and thus gone through the link and find informative.
The doc. shows process switching and CEF switching parameters. I would like to know if this corresponds with the forwarding capacity of router as provided in the data sheet? For eg. cisco 3945 as given in the doc. is
Router      Model     pps           Mbps
ISR G2      3945    982,000      502.78
whereas according to datasheet circuit-speed WAN performance up to
350 Mbps with services.
Appreciate ur help to clarify on this.
Thanks & Regards,
Sandeep
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
For routers:
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
For switches:
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/switchperformance.pdf
