8xT1 MLPP Bundle on Cisco 2811 Router?
ahmad82pkn
Level 3
Level 3
Did any one do that in production?
i am planning to upgrade T1 capacity on one of 2811 Router to achieve 12 Mbps throughput by installing 4xVWIC-2MFT-T1= 8 T1
but on some documentation i see cisco only recommend 2xT1 bundle, although i am running 4xT1 bundle successfully on this router already.
so any one tried 8xT1 bundle on cisco 2811 successfully ? using 4xVWIC-2MFT-T1 card? because documentation does show it can physically load 4 VWIC cards.
alan-asido
Is it possible to make 8xT1 in 2911 router? existing is 4xT1 and assuming Ethernet circuit is not an option.
As also replied to you same question in another thread:
As the documentation I posted 3 years ago notes a 2911 support two 4xT1 modules, you should be able to.  The 2911's performance should be able to easily handle that much bandwidth too.
