a alarm about 7600 SIP200
flyipmm914
SLOT 1: Nov  9 02:24:36.595: %C7600_SIP200_SPIRX-3-SPA_INTERRUPT: SPA 0 -  seq err,  SPA Int status = 0x4
SLOT 1: Nov  9 02:24:36.595: %C7600_SIP200_SPIRX-3-SPI4_LINKERROR: SPA Bay 0,  1 SPI4 Link Failures
Configuration details of POS1/0/1::
MTU: 4470, xmit_delay: 0, CRC: crc32, Framing: sdh, Clock source: internal
Scramble: off, ais_shut: off, tx_j0: 0x1
aps_working: off, aps_protect: off, aps_signalling; SDH MSP
Vector Details:
fastsend            = 0x4025798C, turbofs    = 0x403E1918
multicast fs        = 0x403E1918, tagfs      = 0x00000000
tag optimum fs      = 0x405A67E0, ip2tagfs   = 0x00000000
ip2tag optimum fs   = 0x00000000, ipv62tagfs = 0x00000000
Counters:
Rx Bytes = 145341413880, Tx Bytes = 214696843076
Rx Pkts  = 893943008, Tx Pkts  = 1026362687
Rx CRC Errs = 66291505, Tx Underruns = 0
Rx Giants = 60754, Tx Aborts = 0
Rx Ignore = 0
Rx Runts = 5795603
Rx Aborts= 222904
I think maybe line probelm case this alarm,because there was too may rants.
try to find answer on cisco.com,but failed。what about you opinion? thanks。
Bert Gevers
Hi Ying,
what software version are you running on the 7600?
I believe you may be encountering:
CSCsm80678    SIP-200 logs "%SIP200_SPIRX-3-SPA_INTERRUPT" error message continuously
Externally found minor (Sev4) bug: D-Duplicate
which is fixed through:
CSCsq19146    FPD creation for new pegasus rx (1.6) FPA image for Sip-1 CR
Externally found severe (Sev2) bug: V-Verified
This defect is seen when there is a series of runts received on the card.
I would recommend to upgrade the FTP and IOS on the device to a version which incorporates CSCsq19146.
FPD upgrade instructions can be found here:
http://cisco.biz/en/US/docs/interfaces_modules/shared_port_adapters/configuration/7600series/76fpd.html
Afterwards, verify if the runts are still present as they may be caused by a line problem indeed.
HTH,
Bert
------------------ show version ------------------
IOS (tm) cwlc Software (sip1-DW-M), Version 12.2(18)SXF4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Thu 23-Mar-06 20:09 by tinhuang
Image text-base: 0x40011050, data-base: 0x40700000
ROM: System Bootstrap, Version 12.2(20051006:192046) [rwoods-pikespeak 125], DEVELOPMENT SOFTWARE
ROM: cwlc Software (sip1-DW-M), Version 12.2(18)SXF4, RELEASE SOFTWARE (fc1)
SIP-200-1 uptime is 1 year, 29 weeks, 8 hours, 48 minutes
System restarted at 17:39:44 UTC Sun Apr 19 2009
Running default software
cisco CWAN Sibyte Interface Processor (SB-1) processor (revision 0xFF) with 393216K/131071K bytes of memory.
SB-1 CPU at 800Mhz, Implementation 0x401, Rev 0.2, 512KB L2 Cache
Last reset from power-on
1 FastEthernet/IEEE 802.3 interface
2 Packet over SONET network interfaces
Configuration register is 0x4 (will be 0x0 at next reload)
I have saw that documentation ,thank you very much!
