A bit confused with NAT + 1 weird problem
ROSS_Solar
Dear NetPros!
Recently got a cisco 2851 router + 2 HWIC-1FE cards. Network setup is described in attached jpeg. I've configured ISP failover with ip sla + NAT and pptp VPN server, but still can't figure out how to make FTP server 2 (see attachment) reachable from outside hosts with 1.1.1.4 address. The problem is that LAN2 has its own uplink and default gw, so we need to do NAT with not only inside src address changed, but also need to change outside src address. Can't get it working. Please, help :)
And now the weird problem:
When tested failover uplink switching noticed that when i pull cable out of fa0/1/0 everything works fine (sla monitor + tracking shows reachability->down) but when i return cable back to interface fa0/1/0, iface goes up, proto up, !!but!! 'show track' says reachability still down, 'show ip sla trace' shows timeouts for icmp goin out fa0/1/0. More, when tryin to ping fa0/1/0 address from remote hosts - getting timeouts. The only way to get things working again - reload router. Please advice, how to make it working properly.
With best regards,
Vlad
ROSS_Solar
Please, tell if it is possible to make such a translation at all (see first part of leading post)?
guys, no one can help? i'm really surprised...
Edison Ortiz
Try changing the SLA to ping 1.1.1.1 instead of an address that involves routing such as 192.58.128.30.
Give a try with this config.
ip sla 1
icmp-echo 1.1.1.1 source-interface FastEthernet0/1/0
timeout 1000
threshold 3
frequency 10
ip sla schedule 1 life forever start-time now
Also, remove the ip inspect on that interface while we are troubleshooting this.
__
Edison.
