A Hierarchical QoS Issue
Vivek Bannore
Hi Community,
Scenario:
  • HQ WAN Router already has a QoS Policy applied on its WAN port (30M link) [HQ has several branch sites and no issues with the rest of them except one branch. That one branch will be spoken about in this thread]
  • Branch WAN Router is on a 4M link and has no QoS policy - voice traffic from HQ to Branch is getting affected.
  • ISP QoS is not possible at this moment due to cost reasons
Config:
HQ WAN Router - Current
interface GigabitEthernet0/1
service-policy output wan-qos
class-map match-any mgmt
match access-group name mgmt
class-map match-any ldap
match protocol ldap
class-map match-any abcd
match access-group 112
class-map match-any voip-signal
match protocol skinny
match protocol mgcp
class-map match-any voip-media
match protocol rtp
class-map match-any rdp
match access-group 111
policy-map wan-qos class iccs
    bandwidth 1024
class voip-media
    priority 164
class voip-signal
    bandwidth 48
class rdp
    bandwidth 64
class mgmt
    bandwidth 16
class ldap
    bandwidth 32 class class-default      random-detect
New QoS policy for HQ to Branch voice traffic
***** Classify Voice traffic to Branch *****
access-list 102 permit ip <HQ IP>  <Branch IP>
class-map voice-branch-traffic match access-group 102
***** Giving voice traffic a guarantee of 200 kbps with a burst of ~ 20kbps *****
policy-map Priority-Voice-branch-Traffic
class voice-branch-traffic
  priority 200 20000
***** Max traffic out to branch will be limited to 3.6Mbps (10% reserved) *****
policy-map  branch-Traffic
class class-default
  shape average 3600000
  service-policy Priority-Voice-branch-Traffic
Now to apply this new QoS policy within the already current (wan-qos) of the HQ router, would the following way be correct ?
policy-map wan-qos class abcd
    bandwidth 1024
class voip-media
    priority 164
class voip-signal
    bandwidth 48
class rdp
    bandwidth 64
class mgmt
    bandwidth 16
class ldap
    bandwidth 32 class class-default      shape average 30000000 ----> HQ WAN Link is 30M (random-detect had to be removed to apply the policy)
     service-policy branch-Traffic ---->  Shaping HQ to Branch Voice traffic to be less than 3.6M
Is this the correct way to apply the new "branch-Traffic" QoS policy under the existing one "wan-qos" on the HQ router ?
Vivek
Eugene Khabarov
Level 7
Level 7
Hi! This is correct. Here is the example with policer you can reference:
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t13/feature/guide/ft3level.html
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Hmm, not quite right for the following reasons.
First, if your going shape traffic to 30 Mbps, you need to shape all traffic.  Your parent's shaper is only defined in class-default; other classes could exceed the 30 Mbps limit.
Second, some shapers, I believe don't account for L2 overhead, and if they don't you need to account for that.  Unfortunately, L2 overhead, as a percentages, varies based on frame's size.  (Often setting shaper to 10 to 15% below nominal rate seems to work okay.)
Third, when supporting VoIP, where jitter is a consideration, you may need to minimize Tc from default.  Different platforms/IOSs have different defaults, usually either 4 ms or 25 ms.
Forth, ideally you would want to shape all 4 Mbps for the branch, also using the above considerations, but if a 3 level hierarchy isn't supported, yours is good, but again because of strict timing considerations for VoIP, you want the child's shaper to use a small Tc too.  For this configuration, you do want a separate child class for VoIP, but LLQ won't really trigger unless the child policy sees congestion at the parent's shaper.
PS:
Also working VoIP, you sometimes also need to adjust tx-ring-limit.
Thank you for your comments Eugene & Joseph.
The physical interface has a limit placed on it as 30M bandwidth and so the bandwidth within the classes of "wan-qos" should come into effect and not send anything more than the 30M limit set of the interface.
All other branches have good bandwidth wan links except this particular branch which only has a 4m link. I think a 3-level hierarchy is supported on the WAN router. The only issue was I wasn't sure if my configuration was following the best pratice in terms of combining the QoS policies.
So the way I have configured and combined the QoS policy, is that correct ? I'll research the tx-ring-limit and Tc values as well.
Vivek
Disclaimer
Posting
"The physical interface has a limit placed on it as 30M bandwidth and so  the bandwidth within the classes of "wan-qos" should come into effect  and not send anything more than the 30M limit set of the interface."
I would expect a rate limit, but you miss the issue.  If class-default is shaped to 30 Mbps while class abcd adds another 10 Mbps, your policy would allow sending 40 Mbps but the provider's rate limiter will drop 25% of your traffic.  Problem is, the 25% can also be your class-default.  Rate limiters don't create back pressure, i.e. nothing is queued.
"I think a 3-level hierarchy is supported on the WAN router. The only  issue was I wasn't sure if my configuration was following the best  pratice in terms of combining the QoS policies.
So  the way I have configured and combined the QoS policy, is that correct ?  I'll research the tx-ring-limit and Tc values as well."
If a 3-level is supported, you want a structure something like:
policy-map level1
class class-default
service policy level2
policy-map level2
class abcd
bandwidth x
class ldap
bandwidth y
class special-branch
shape average 4000000
service policy level3
policy-map level3
class voice
priority 200
class class-default
fair-queue
