a ISR4431-V/K9 support a gatekeeper funcionality?
I replace a router ASR for  a ISR 4431, and  need this funcionality
Gatekeeper has been replaced by SME
regards
6 Replies 6
as far as I recall, the ISR 44xx does not support the gatekeeper functionality at all.
What functionality replaces the gatekeeper in the ISR4K, should I buy an
additional license, what should I do?
the 4431 supports the Integrated IP PBX ( Cisco Unified Communications Express) and Session Border Controller ( Cisco Unified Border Element, or CUBE). You need a 'Voice' license (check Table 5 of the attached datasheet)...
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet-c78-732542.html#ISR4000InterfacesandModulesSupport
I have ISR 4431-V with IP Base + Unified Communications: CME, SRST, CUBE, I
need a configuration guide, where I am guided on how I can convert the
gatekeeper configuration to CUBE or what I have to do
check out the guide linked below:
Cisco Unified Border Element Configuration Guide
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book.html
regards
