A NEW DESIGN
vipinrajrc
Level 3
Level 3
Hi Experts,
This is a new assignment i got. right now all these devices are iin 192.168.1.0/24 network.
This network is in remote location. I may get an onsite help. Now all the devices are connected to each other in a rapid manner.
They are some how managed to provide internet to the users.
But i need to connect the network devices in the following manner
ISP router ---> 1811 router ---> 2960 switch --> IP phones
                                       ---> 3550 switch --> servers
Please see attached network diagram for my proposal.
ISP router is also in the client's permimeter and we have access to the ISP router. It is terminating a dsl account
with a dynamic public IP. This ISP router is also act as a DHCP router for internal hosts.
As i said right now they are connecting in Triangle manner. Like 1811-->2960-->3550-->1811.
And ISP router is conencted to one of the switch.
ISP router is motorola netopia3000 series. It is capable of NATing.
They have tried to connect the network devices as i said. But they lost the internet connectivity at the same moment.
This may be due the lack of default route in router, right?? I didnt try with the default route configuration.
I need to segregate like below...
ISP -- to -- 1811 -->192.168.1.0 /24
1811 -- to -- 2960 -->192.168.3.0/24
1811 -- to -- 3550 -->192.168.2.0 /24.
I have tried the same in packet tracer. In packet tracer the server in 192.168.2.0/24 range is able to ping to 192.168.1.254 which is the
of the ISP router. This is acheived by adding a static route in ISP router.
I hope everyone understand my scenario.............
My doubt is like
1) how / Where can i NAT exchange server private IP address???
Exchange serer private IP is 192.168.2.5, public IP is 105.15.11.15.
Where should I NAT for this exchange server?
2)  for giving internet access to users i need to configure only a default route in 1811 right?
    Right now they are having internet using the default gateway as ISP router.
Please suggest your valuable informations...........
Vipin
Thanks and Regards, Vipin
5 Replies 5
andrew.prince
Level 10
Level 10
Answers:-
1) NAT on the 1811
2) All internal devices should have the 1811 "Inside" interface IP as their default gateway
HTH>
use this static nat statement for exchange
ip nat source static 192.168.2.5 102.15.11.15 .
if u want allow only port 25 and 443,then edit this command with tcp port
keep the default to IPS
Hi Shehin,
Thanks for the reply.............
Is it possible to NAT in the router which is having private IP address in the outside interface????
Vipin
Hi Andrew,
Yes, ofcourse NAT is possible in 1811 router. But the problem is IP address between 1811 router and ISP router are private.
So how can i NAT??
Can i use double NAT?? I did a double portforwarding once in a checkpoint router... Will it work in the same way here???
Vipin
You can use nat anywhere it is no limited to public & private.
