a problem with cisco 7604 router
yamenginena
Dear All,
i am having a problem with Cisco 7604 router with SUP-32, i enabled logging buffered debugging and although that there is no logging appear when i write show logging when interface up or down only logs for %SYS-5-CONFIG_I: Configured from console
does anyone has a solution for this issue.
2 Accepted Solutions
I mean the first lines of the "show logg" where you can find the information about level, sizw and so on.
Which Interface do you expect to se in the logging -   port 1/5?
your Cosole logging is disable -  "Console logging: disabled". Try to enable it, may this is the problem.
13 Replies 13
do you see the UP/DOWN  logging messages on the console port or on the VTY after "term mon" command?
no i can`t also see logging on console neither on vty with term mon
show please the output of "show log" command.
these are the show log
Oct 26 09:27:15.751 EST: %SYS-6-EXIT_CONFIG: User YA has exited tty session 1(192.168.1.100)
Oct 26 10:24:51.401 EST: %SYS-5-CONFIG_I: Configured from console by YM on vty1 (192.168.1.101)
Oct 26 10:25:02.942 EST: %SYS-6-EXIT_CONFIG: User YM has exited tty session 2(192.168.1.101)
Oct 26 10:25:27.056 EST: %SYS-6-EXIT_CONFIG: User YT has exited tty session 1(192.168.1.100)
Oct 26 10:29:18.264 EST: %SYS-5-CONFIG_I: Configured from console by YA on vty0 (192.168.1.100)
Oct 26 10:29:26.489 EST: %SYS-6-EXIT_CONFIG: User YA has exited tty session 1(192.168.1.100)
Oct 27 09:21:58.401 EST: %SYS-6-EXIT_CONFIG: User YA has exited tty session 1(192.168.1.100)
Oct 27 14:07:10.560 EST: %SYS-5-CONFIG_I: Configured from console by YA on vty0 (192.168.1.100)
Oct 27 14:07:25.449 EST: %SYS-6-EXIT_CONFIG: User YA has exited tty session 1(192.168.1.100)
Oct 30 09:12:12.634 EST: %SYS-6-EXIT_CONFIG: User YA has exited tty session 1(192.168.1.100)
Oct 31 11:26:40.831 EST: %SYS-6-EXIT_CONFIG: User YA has exited tty session 1(192.168.1.100)
Nov  1 09:03:59.114 EST: %SYS-6-EXIT_CONFIG: User YA has exited tty session 1(192.168.1.100)
Nov  2 09:09:34.067 EST: %SYS-6-EXIT_CONFIG: User YA has exited tty session 1(192.168.1.100)
Nov  2 14:49:06.261 EST: %SYS-5-CONFIG_I: Configured from console by YA on vty0 (192.168.1.100)
Nov  2 14:49:33.103 EST: %SYS-6-EXIT_CONFIG: User YA has exited tty session 1(192.168.1.100)
Nov  2 15:48:05.613 EST: %SYS-5-CONFIG_I: Configured from console by YA on vty0 (192.168.1.100)
Nov  2 15:52:31.512 EST: %SYS-5-CONFIG_I: Configured from console by YA on vty0 (192.168.1.100)
Nov  2 16:08:01.596 EST: %SYS-6-EXIT_CONFIG: User YM has exited tty session 2(192.168.1.100)
Nov  2 16:10:53.622 EST: %SYS-6-EXIT_CONFIG: User YA has exited tty session 1(192.168.1.100)
Nov  2 16:18:15.742 EST: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 1: TestTransceiverIntegrity failed on port(s) 5
Nov  2 16:18:15.742 EST: %PM_SCP-SP-3-TRANSCEIVER_UNSUPPORTED: Unsupported transceiver in LAN port 1/5
Nov  2 16:21:16.538 EST: %SYS-6-EXIT_CONFIG: User YA has exited tty session 1(192.168.1.100)
Nov  2 16:30:33.027 EST: %SYS-5-CONFIG_I: Configured from console by YM on vty1 (192.168.1.100)
Nov  2 16:41:49.985 EST: %SYS-6-EXIT_CONFIG: User YM has exited tty session 2(192.168.1.100)
Nov  2 16:41:49.985 EST: %SYS-5-CONFIG_I: Configured from console by YM on vty1 (192.168.1.100)
Nov  2 16:45:42.029 EST: %SYS-6-EXIT_CONFIG: User YA has exited tty session 1(192.168.1.100)
Nov  2 16:45:42.029 EST: %SYS-5-CONFIG_I: Configured from console by YA on vty0 (192.168.1.100)
Nov  3 09:33:50.991 EST: %SYS-6-EXIT_CONFIG: User YA has exited tty session 1(192.168.1.100)
Nov  3 09:40:39.949 EST: %SYS-6-EXIT_CONFIG: User YA has exited tty session 1(192.168.1.100)
Nov  3 12:53:42.862 EST: %SYS-6-EXIT_CONFIG: User YA has exited tty session 1(192.168.1.100)
Nov  3 12:58:05.101 EST: %SYS-5-CONFIG_I: Configured from console by YM on vty1 (192.168.1.100)
Nov  3 12:58:34.936 EST: %SYS-5-CONFIG_I: Configured from console by YM on vty1 (192.168.1.100)
Nov  3 13:01:53.636 EST: %SYS-5-CONFIG_I: Configured from console by YM on vty1 (192.168.1.100)
Nov  3 13:19:39.575 EST: %SYS-6-EXIT_CONFIG: User YM has exited tty session 2(192.168.1.100)
Nov  3 13:19:39.575 EST: %SYS-5-CONFIG_I: Configured from console by YM on vty1 (192.168.1.100) Oct 26 09:27:15.751 EST: %SYS-6-EXIT_CONFIG: User YA has exited tty session 1(192.168.1.100)
i try to log any interface by shutdown  and no shut and nothing appear and i know the transceiver on 1/5 is not supported but this is not the interface i want to see log about
here is the logging
Syslog logging: enabled (0 messages dropped, 3 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 74 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 71 message lines logged
        Logging to 10.30.0.21  (udp port 514,  audit disabled,
              authentication disabled, encryption disabled, link up),
              47 message lines logged,
              0 message lines rate-limited,
              0 message lines dropped-by-MD,
              xml disabled, sequence number disabled
              filtering disabled
i alredy done that and enable console and nothing about interfaces appear except the other logs not about interfaces status and i get it back disabled
it really strange, are you sure your interfaces going DOWN and UP?
try to increase the logging buffer size
hi,
try adding the "logging event link-status" command under the interfaces you want to monitor.
is this command not a default?
no it's not (i've checked with one of our 7606s).
on a side note, you may want to configure "logging event link-status default" under global config mode to monitor up/down message for your all interfaces.
oh! you're right, there is a command "logging event link-status default" in our configuration,
never late to learn something
