A question on Router-IDs of BGP VRFs
ruiminamzn
Hi there,
Currently, we're using BGP vrf feature on Switch 3750x and we have created many vrfs for different connections. Our current settings look like,
router bgp 65000
bgp log-neighbor-changes
timers bgp 5 20
address-family ipv4 vrf first-connection
  bgp router-id auto-assign
  network 192.168.1.0
  neighbor 192.168.254.1 remote-as 9059
  neighbor 192.168.254.1 password ***password***
  neighbor 192.168.254.1 activate
  neighbor 192.168.254.5 remote-as 9059
  neighbor 192.168.254.5 password ***password***
  neighbor 192.168.254.5 activate
exit-address-family
address-family ipv4 vrf second-connection
  network 192.168.2.0
  neighbor 192.168.254.254.9 remote-as 9059
  neighbor 192.168.254.9 password ***password***
  neighbor 192.168.254.9 activate
  neighbor 192.168.254.13 remote-as 9059
  neighbor 192.168.254.13 password ***password***
  neighbor 192.168.254.13 activate
exit-address-family
As you see, we duplicated "bgp router-id auto-assign" in each BGP vrf setting, now we're proposing to use "bgp router-id vrf auto-assign" for all vrfs instead of above each individual settings, the commands we will enter are,
conf t
router bgp 65000
bpg router-id vrf auto-assign
no bgp router-id auto-assign
exit
exit
end
The result would be as,
router bgp 65000
timers bgp 5 20
  network 192.168.1.0
exit-address-family
  network 192.168.2.0
exit-address-family
Here is my question, because the Router IDs may be affected by the above commands, so will the above commands result in some vrfstemporarily down for a while (for example, 30 seconds offline)? I'm not quite sure on whether Router ID will be reset because every VRF has its own Router ID now.
Thanks for the help.
Ray
0 Replies 0
