AAA new-model locks out ssl
ktravis02
Hi, I enable aaa on my ISR 4331, and got locked out of ssl. login local was removed from line vty 0 4, and won't allow me to put it back. I found a command, aaa authentication login default local; line vty 04; login authentication default, but those commands are not available on the ISR 4331.
How do I enable aaa and keep SSL access?
Thanks, -ken
Philip D'Ath
I'm thinking you mean ssh access since you keep mentioning "line vty ...".
You should only need to enter this single line:
I would also add:
aaa authorization exec default local
Philip D'Ath
I would also add:
Thanks, that did it.
