Route-map using 02 internet circuit
marcio.tormente
Level 4
Level 4
Hello guys!
Please, I need help with one issue that I'm facing.
I have 02 sites (A and B) connected by MPLS, both sites have internet circuit, but after internet circuit of site B goes down, the default route was changed to use the internet from site A.
After this change one Web Server that is on site B stopped to work, the reason is that this server uses a public IP from the internet from site B.
To solve this issue I create a PBR with ACL source the private IP (source) to any (destination)
Next-hop is the internet fw of site B.
Extended IP access list LOCAWEB
10 permit IP host 10.166.115.10 any
20 permit IP host 10.166.115.11 any
route-map ROUTE-LOCAWEB, permit, sequence 10
Match clauses:
ip address (access-lists): LOCAWEB
Set clauses:
ip next-hop 10.166.64.1
Policy routing matches: 0 packets, 0 bytes
The Web Server is working, but I lose connectivity with the server using internal IP. All my network is 10.0.0.0/8.
I already tried to change the ACL and put the rule below, but when I do it both (internal and external) communication stop to work.
08 deny ip host 10.166.115.10 10.0.0.0 255.0.0.0
09 deny ip host 10.166.115.11 10.0.0.0 255.0.0.0
Does anyone know how to solve this issue?
Marcio
Hello
Probably need to amend you access-list to deny PBR for traffic between your host and the 10.0.0.0/8
ip access-list extended LOCALWEB
permit ip host 10.166.115.10 10.0.0.0 0.255.255.255
permit ip 10.0.0.0 0.255.255.255 host 10.166.115.10
permit ip host 10.166.115.11 10.0.0.0 0.255.255.255
permit ip 10.0.0.0 0.255.255.255 host 10.166.115.11
route-map ROUTE-LOCAWEB deny 5
match ip address LOCALWEB
route-map ROUTE-LOCAWEB  permit 10
no match ip address LOCALWEB
set ip next-hop 10.166.64.1
Kind Regards
Paul
5 Replies 5
Hello
Kind Regards
Paul
Hello Paul,
In your ACL is considering just the communication with network 10.0.0.0/8, in this case, the traffic to the internet should continue using default route and going to Site A, right?
I made the change and worked fine.
Thank you very much
Hello
Glad to see its working - Thank You for the feedback and rating.
Kind Regards
Paul
Giuseppe Larosa
Hello Marcio,
ACLs use wildcard mask so the additional lines should be:
08 deny ip host 10.116.15.10 10.0.0.0 0.255.255.255
09 deny ip host 10.116.15.11 10.0.0.0 0.255.255.255
Hope to help
Giuseppe
