AAA Password Problem
msrbelfast
I need some help, I'm having an issue with the passwords on my switches and routers... I can't access them remotely?!
I'd be very grateful if someone could tell me if there's something I've done wrong?
Attached.
Many thanks,
Matt
I need more than wireshark to troubleshooting the issue,
can you share the config ??
I've shared the pkt file in the zip attached to the original post, if that works for you?
IP_Cartel
please share:
AAA
line vty
outputs
The zip attached to the OP contains the pkt file if that helps?
