About Router NAT Configuration Consultation
I have a C1111 router and I configured the following static NAT.
ip nat inside source static 192.168.2.190 172.25.139.241
ip nat inside source static 192.168.2.191 172.25.139.242
ip nat inside source static network 192.168.2.0 192.168.61.0 /24
I would like to know whether the third static NAT configuration will conflict with the previous two static NAT configurations?
What I want to achieve is that 192.168.2.100 and 192.168.2.101 are NATed to 172.25.139.241 and 172.25.139.242 respectively, and the other addresses of 192.168.2.0/24 are NATed to 192.168.61.0/24
3 Accepted Solutions
Hello
@haininghuang3185 wrote:
Then I need to add the above configuration:
I am not sure whether the newly added commands will conflict with the original NAT configuration.
No it WILL not conflict, you will be fine adding this, it will just create an additional permanent static mapping in the translation table along with the other two static mappings prior to any translation.
example::
Inside global               Inside local
Kind Regards
Paul
Friend the router seach NAT for same ingress and egress for host  192.168.2.190 (example) one by one
First  it will match NAT
So it will not continue to match other NAT
that make 2.190 and 2.191 never NATing to 192.168.61.x
And it worse if he add
Ip nat inside source static network
Above all other NAT.
So we need to find away to solve this conflict.
The idea I have is he use route-map for first two static NAT' where if source is 2.190/2.191 and destiantion is specfic then he will use these NAT
If not the router will match last NAT
MHM
@haininghuang3185
Just to clarify once more , you will be okay to add that additional static network statement you do not require any route-map statement.
Kind Regards
Paul
24 Replies 24
There is no such this command
What try to do here?
MHM
There is such a command, which I can configure on the C1111 router. Now I need to add a command, which is ip nat inside source static network 192.168.2.0 192.168.61.0 /24, but I am not sure whether this command will affect my original two commands
Friends there is
One to one
One to many (using pool)
But there is No
Many to many
MHM
Hello friend,
this command is also one-to-one NAT, which is to implement one-to-one NAT of the entire address segment, 192.168.2.0/24 NAT 192.168.61.0/24
You can look at this post
https://community.cisco.com/t5/routing/static-nat-for-a-complete-subnet/m-p/1297182#M122385
First time I see such this command,
But you are correct
It one to one if both real and mapped IP use same prefix
And there is no conflict since the real and mapped IP not use in other NAT
MHM
Hello
@MHM Cisco World
But there is No
Many to many
MHM
incorrect yes there is such a feature that can be used  like - ip nat inside source static network 192.168.2.0 192.168.61.0 /24
Kind Regards
Paul
Sorry but why the original post show
192.168.2.0 and screenshot 192.168.100.0?
If it 192.168.100.0 this command not conflict
If it 192.168.2.0 then there is conflicts
MHM
I currently need to add a command to the original configuration
Are the ingress and egress of both NAT same?
İf not then there is no issue if same then there is conflict.
MHM
The equipment configuration is as follows:
interface GigabitEthernet0/1/0
switchport access vlan 10
switchport mode access
interface GigabitEthernet0/1/2
switchport access vlan 101
interface Vlan10
ip address 10.1.32.98 255.255.255.252
ip nat outside
interface Vlan101
ip address 192.168.0.6 255.255.255.248
ip nat inside
If one inside and one outside sure it will conflict.
Do you want to check this case in my lab?
MHM
It would be better if you can help test it in LAB
Hello
no it should not conflict however, you do have another option and that would be to use an access-list .and deny those static nat from the inside local address range (192.168.2.0/24)
access-list 100 deny ip host 192.168.2.100 any
access-list 100 deny ip host 192.168.2.101 any
access-list 100 permit ip 192.168.2.0 0.0.0.255  any
no ip nat inside source static network 192.168.2.0 192.168.61.0 /24
ip nat pool POOL 192.168.61.1 192.168.61.254 prefix-length 24
ip nat inside source list 100 pool POOL
Kind Regards
Paul
I don't want to do dynamic NAT, because I want to implement one-to-one NAT for the entire network segment,
for example
192.168.2.1 NAT 192.168.61.1
192.168.2.2 NAT 192.168.61.2
192.168.2.3 NAT 192.168.61.3
192.168.2.253 NAT 192.168.61.253
192.168.2.254 NAT 192.168.61.254
