About Router NAT Configuration Consultation
I have a C1111 router and I configured the following static NAT.
ip nat inside source static 192.168.2.190 172.25.139.241
ip nat inside source static 192.168.2.191 172.25.139.242
ip nat inside source static network 192.168.2.0 192.168.61.0 /24
I would like to know whether the third static NAT configuration will conflict with the previous two static NAT configurations?
What I want to achieve is that 192.168.2.100 and 192.168.2.101 are NATed to 172.25.139.241 and 172.25.139.242 respectively, and the other addresses of 192.168.2.0/24 are NATed to 192.168.61.0/24
24 Replies 24
Hello @haininghuang3185
Nw I understand...so then you should be okay with the cfg you already have applied........however yet another option may be applicable would be to used nat " match-host"
ip nat pool POOL 192.168.61.1 192.168.61.254 prefix-length 24 type match-host
this will match inside local to inside global addressing
Kind Regards
Paul
İp nat Inside source static network
Not use pool at all.
MHM
Hello
@haininghuang3185 wrote:
Then I need to add the above configuration:
I am not sure whether the newly added commands will conflict with the original NAT configuration.
No it WILL not conflict, you will be fine adding this, it will just create an additional permanent static mapping in the translation table along with the other two static mappings prior to any translation.
example::
Inside global               Inside local
Kind Regards
Paul
2.190 and 2.191 will always NAT usign first two NaT line and never NaT to 192.168.61.0
This conflict.
MHM
@MHM Cisco World
Can you elaborate?
Kind Regards
Paul
Friend the router seach NAT for same ingress and egress for host  192.168.2.190 (example) one by one
First  it will match NAT
So it will not continue to match other NAT
that make 2.190 and 2.191 never NATing to 192.168.61.x
And it worse if he add
Ip nat inside source static network
Above all other NAT.
So we need to find away to solve this conflict.
The idea I have is he use route-map for first two static NAT' where if source is 2.190/2.191 and destiantion is specfic then he will use these NAT
If not the router will match last NAT
MHM
If so, then I can achieve my needs.
I want to achieve is that 192.168.2.100 and 192.168.2.101 are NAT to 172.25.139.241 and 172.25.139.242 respectively, and the other addresses of 192.168.2.0/24 are NAT to 192.168.61.0/24.
If that so there is not conflict you can use both NAT
MHM
Hello
You are incorrect in your thinking
Remember these are the two single specific static nat mappings so they will NEVER nat to 192.168.61.x as they are STATIC (1-2-1 mapping)
So adding the any other none specified staitc network mapping will ONLY use the 192.168.2.0 <> 192.168.61.0 nat statement and not conflict
Kind Regards
Paul
@haininghuang3185
Just to clarify once more , you will be okay to add that additional static network statement you do not require any route-map statement.
Kind Regards
Paul
