about the RSP4 issue!!!!!
haijason
Hi,I have a running 7507 with two RSP4 card. The RSP4 has 32M flash card inside.There is a issue that 32M flash card cannot support the IOS with more 32M. I want to order the MEM-RSP4+-FLD64M to fulfill my aim.But I don't know whether the RSP4 can support the MEM-RSP4+-FLD64M to run well.
Pls help me to confirm the issue.
Thanks a lot.
Sincerely
amit-singh
Level 8
Level 8
The memory MEM-RSP4+-FLD64M is only supported with the route processor RSP4+, its not supported on RSP2 or RSP4.
If you have 7500's with RSP4+ it will work, otherwise it will not work.
http://www.cisco.com/en/US/products/hw/routers/ps359/prod_bulletin09186a00801ebebe.html
HTH,
-amit singh
