Access Control List Details
Cmurdochi
Hello!
I am trying to find out if there is a way to see additional details about access control lists applied to Cisco routers (no specific router in mind). My new job deals heavily with ACLs and I would like to see how long certain ones have been applied, but I haven't come across any documentation detailing how I would go about doing that.
Thank you!
Francesco Molino
In ASA family, to support more than 100 vpn users, you should take a look at 5516. If costs a bit not than 5k but with discounts you should get in there.
In terms of routers, supporting 105 vpn users, you won't get something in your budget.
Also for ASA, in your price range, you'll have 1G interface but won't support 1G bandwidth.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
rasmus.elmholt
Level 7
Level 7
I don't know any commands that will show you how long an ACL was applied on an interface. But show ip access-list can show you hitcounts and so on.
I would recommend looking at a configuration revision and management system.
