Access Control List
dacruzer1
Level 3
Level 3
Hello Everyone!
Is there a one-liner I can create for this ACL:
The source IPs are all the same and the destination IP are also the same
access-list 187 permit tcp 10.30.0.0 0.0.255.255 host 10.10.77.10 eq 5938
access-list 187 permit tcp 10.30.0.0 0.0.255.255 host 10.10.77.10 eq 7710
access-list 187 permit tcp 10.30.0.0 0.0.255.255 host 10.10.77.10 eq 3310
access-list 187 permit tcp 10.30.0.0 0.0.255.255 host 10.10.77.10 eq 2310
access-list 187 permit tcp 10.30.0.0 0.0.255.255 host 10.10.77.10 eq 3870
access-list 187 permit tcp 10.30.0.0 0.0.255.255 host 10.10.77.10 eq 2342
Thanks!
2 Accepted Solutions
Hello
If your software supports it then you could try a service object group and tie that into a single extended acl.
object-group service tcp_ports
tcp eq 5938
tcp eq 7710
tcp eq 3310
tcp eq 2310
tcp eq 3870
tcp eq 2342
ip access-list extended 187
permit object-group tcp_ports 10.30.0.0 0.0.255.255 host 10.10.77.10
int x/x
ip access-group 187 in/out
Kind Regards
Paul
Georg Pauwen
a named access list lets you put it multiple values:
ip access-list extended TCP_PORTS
permit tcp 10.30.0.0 0.0.255.255 host 10.10.77.10 eq 2310 2342 3310 3870 5938 7710
5 Replies 5
Hello
tcp eq 5938
tcp eq 7710
tcp eq 3310
tcp eq 2310
tcp eq 3870
tcp eq 2342
int x/x
Kind Regards
Paul
Hi Paul,
Thanks for your help, I will definitely use this solution. Also, Is the an object group for IPs?
Thanks, Alfred
Hello
@dacruzer1 wrote:
Hi Paul,
Thanks, Alfred
Glad it assisted you, yes there is
object-group network <name>
range 192.168.1.0 192.168.1.254  < ip range
192.168.1.0 255.255.255.0 <  ip subnet
host 192.168.1.1 < ip host
group-object  xxx < nested group object
Kind Regards
Paul
Georg Pauwen
Thanks George! I appreciate your help.
